Thanks for the great feedback - I prob should have been a bit more clear in my question - not just "what DMM do you use", but also "why did you pick that one, what do you like/dislike about it".
I have a lot (and forgot at least one - UNI-T UT-210 clamp meter)... Some are general, but several of them I picked up for various reasons over the years (which I tried to hint at in my original post)
Like I said, not looking to get any new ones, but curious to know if I'm missing out on anything super-handy, and also could be a good resource for someone looking to get one.
--- Likes
I like the 4.5 digits, esp when they have a 2ua scale .. means I can detect current 0.0001ua (almost none - at at that range the low digit "bobbles" but you can usually tell if it leans more one-way than the other - why would I care about such low-current? It mattered when I replaced the unobtanium rechargable in my Logiteck solar keyboards with more common coin cells - didn't want to make it look gross blocking the solar cells, and was able to verify that the CR2032s I chose didn't take ANY "reverse charge".. also important when figuring
out how a circuit drains.
The MN-35 can measure temperature - I was working on something where we had to keep a part from overheating and this made it much easier to check "where it was".
The 22-168A has lots of "stuff", but the main reason I picked it up was that I wanted to record readings for a length of time - and this one has an RS-232 cable which lets you "query" it's reading from a computer with a serial port. (This is mitigated now as the UT-81B has an I/R interface with a USB adapter to fit it... I "figured out" the protocol, it's also a simple serial connection, and I made my own I/R <> RS-232 interface for it)
Some of them can do 10A or more - which makes them much more useful in checking current draw in many cases,'
The clamp meter is a godsend, can measure 200a and super easy to clamp on to a power wire.
Some have extra testing capability (freq. Capacitors, transistors etc.) which at time is really helpful.
The super-small ones are great to "stuff in your suitcase" along with your "travel toolkit" - you never know what you're going to have to fix!
-- Dislikes
The 22-168A has a little insulating cover for it's battery which must have taken some time to design in such a way that it doesn't fit over almost all batteries. Also the continuity function (which I use a LOT) is dog-slow. I like to hear an instant beep. not have to wait a second.
I had one of the LCD displays come partially unbonded in one of my 8060A. Really annoying as it made segments go dim or not at all - spent a few months trying to get the connections to line-up "just right" but couldn't get it to stay aligned. Just tried a "trick" I figured out with the same issue on one of my Hex calcuators, a rubber presure pad to keep in place with the cover screwed down - and now it's working well again (which is what I was doing when I noticed how many meters I still have).
Some of them seem almost "too auto" ... being a bit hard to get to stay in a range. I tend to know what I'm looking for and therefore tend to prefer the non-auto ones.
--- and ... meters are only a small part of a lab - Worth discussing other common (and often wanted) lab tools? I *thought* I had really downsized in recent years, but...
I still have 7 scopes, a few logic analysers, L/C meters, power monitors, freq. counters, signal generators, bunch of device programmers, couple in-circuit emulators, a transmision line/SWR analyser ... the list goes on. Admittedly much of which is of less interest to vintage games and other users of classic PCs ... most of my work was in dedicated small embedded systems.
Just thinking that these forums could be a good way to share our opinions and experiences with what can be some of the most important (and expensive) things we buy to support our "hobby".
