First post, by Rav
I got a Pentium MMX system not so long ago and I have some weird issues I did not have on my 486, not sure where they might come from
1 - Stutters on windows nt4, mainly if I move windows around, It will have mini freeze during easily up 2 seconds. Sound, if playing during that time would stututututututututter. Stutters also happen when I open network drives.
2 - Descent 1 game will have mini slowdown every few seconds (That issue was not present in my 486)
3 - Transport Tycoon Deluxe "install.exe" hang the system (Used to work on the 486, Tryed with dos7, 6.22, with all the kitchen sink loaded, with nothing loaded and with the minimum. Tested with himem, xmgr, and qemm.)
4 - CPU won't even be stable with a small 233 overclock
The board is : A-Trend ATC-5130 ( https://theretroweb.com/motherboards/s/a-trend-atc-5130 )
The chipset is : Ali Aladdin IV+ (M1531)
The CPU is : Pentium MMX 200 (Plastic package)
The video card is : S3 Vision968 PCI 2MB, without the memory expansion board ( https://theretroweb.com/expansioncards/s/diam … -video-vram-pci )
The network card : 3COM 3C905B ( https://theretroweb.com/expansioncards/s/3com … l-pci-3c905b-tx )
The Sound card : Pro Audio Spectrum 16 (Used for PAS16 supported games and for FM)
The Other Sound card : Creative Vibra16C CQM edition (Used for games that don't support the PAS16, FM is DISABLED)
The sound cards are the only parts I pulled out from the 486
I did read something about "PCI Latency", not sure if it's that and if so how to fix it.
