First post, by havli
Over the years I had many Voodoo2 SLI builds. All eventually ended up disassembled because I didn't like the setup.
This time I decided to make really special one, that will last. 😀
V2 is probably the most common 3dfx product, so everyone has one and with few exceptions all the cards utilize reference PCB design... Therefore they all look 95% the same. I wanted to have something special in my build, so I decided to pick Quantum3D card. While the Mercury brick would be ideal, I'm not lucky enough to have one 😁 So the Obsidian2 X-24 will have to do.
Here are the specs:
  • Intel Pentium III 650
  • Intel SR440BX
  • 256 MB SDRAM
  • Onboard Riva TNT 16 MB
  • Quantum3D Obsidian2 X-24
  • Creative ES1373 onboard audio
  • Intel SSD 120 GB SSD
  • IDE DVD drive
  • Intel Pro/100 LAN
  • Corsair VS550
  • Chieftec CI-02B-OP
  • Windows 98 SE
The attachment Obsidian2_X24.jpg is no longer available
The Voodoo card was set, now the rest of the HW. The famous competitor of V2 in 1998 was Riva TNT. The most hiend gaming rigs at the time used both TNT and V2 SLI... and I want that too. But regular TNT is too common and ordinary for my taste. Luckily I found just the right thing and it wasn't even that expensive. 😀
The Intel SR440BX - very nice board that combines all the features I want - microATX format, i440BX chipset....and integrated Riva TNT. 😁 At this time it was kinda popular move to put dedicated GPU on a motherboard. From the top of my head there are Rage Pro, Riva 128, Voodoo3 and perhaps some others. TNT on this board is almost as fast as regular dedicated AGP versions. It uses 16MB/128-bit SDRAM and AGP 1x bus. Clocked at 85/100 MHz (instead of 90/110 like most TNTs do). Integrated TNT is not the fastest one, but definitely unique and perfect fit for this build as it will serve as 2D card most of the time.
The attachment TNT_onboard.jpg is no longer available
Another good feature is onboard audio. ES1373 is no hiend, but decent option for windows games. Not sure how it performs in DOS... but that is not the target here.
The original plan was to run PIII 500 with Katmai core. I have one with passive heatsink that fits nicely to this silent build. For some time the CPU was in (as can be seen on some photos). Unfortunately V2 SLI needs faster CPU to avoid bottlenecks. Luckily the SR440BX can run Coppermines, so PIII 650 was called to action. Faster CPU would be even better, but prices of 800+ native Slot 1 PIIIs are not very friendly and I don't like S370-S1 adapters. 😀
The attachment PIII_650.jpg is no longer available
The Q3D slogan sounds funny these days as this brand is anything but affordable, at least when it comes to 3dfx based products 😁
The attachment Affordable.jpg is no longer available
V2 SLI can get very hot, proper cooling is a must have. Even with 80mm fan blowing directly at the chips, the CK runs at ~60°C. Not much more can be done unfortunately... glued heatsinks would look weird.
The attachment Cooling.jpg is no longer available
Reply 1 of 6, by havli
More photos 😀
The attachment CPU_side.jpg is no longer available
The attachment Obdisian_side.jpg is no longer available
The attachment Obdisian_side2.jpg is no longer available
Classic V2 SLI for testing compatibility with the motherboard before plugging in the Obsidian.
The attachment V2_SLI.jpg is no longer available
The attachment Case_front.jpg is no longer available
Reply 2 of 6, by havli
Medusa cable is needed for proper function and the original is of course unobtanium. Luckily the schematic is available and with a bit of patience, new one can be made.
The attachment Medusa_cable.jpg is no longer available
And now a few screenshots. 😀
The attachment post_screen.jpg is no longer available
The attachment hw-scr.png is no longer available
The attachment hw-scr2.png is no longer available
I started to put this build together a year ago. Back then I also recorded Half-Life gameplay. At the time I still ran PIII 500 and fps drops were noticeable. Now with 650, minimum fps improved significantly. It is still not rock solid 60 fps... but great retro gaming experience. 😀
https://www.youtube.com/watch?v=jO8KECx3GLA
Reply 3 of 6, by VGApocalypse
I alway was very happy with my intel RC440BX (nearly the same as yours but with a Riva128 onboard) DOS/95 slim form factor retro rig. But then I thought about the SR440BX to spice things up a bit. Onboard soundblaster, too - and best of all a TNT. So I bought one. But then things got interesting:
That's no TNT onboard... it happens to be a TNT2M64 with 16 Megs. What sort of late revision is that? Never read anything about that variant.
I don't think there is much of a performance difference to a TNT1, but one never can be sure what to get when buying untested things on ebay.
The "unknown" processor on it turned out to be a Celeron 300 (non A) whose pins were already taped to run at 450Mhz. Still quite slow due to the nonexistent L2 cache btw, therefore swapped to a 500Mhz PIII.
Anyway, I came here to admire those voodoo specialties originally: "Very nice build, indeed!"
Hoarding the precious, worshipping the ancient, playing the forgotten.
Reply 4 of 6, by havli
Thanks 😀
Interesting, I had no idea SR440BX was also made with TNT2 m64. Do you have a photo? I woul like to see how they changed the PCB design.
Performance wise it will be similar to regular TNT (1). Perhaps slightly lower in high resolutions - but such settings wouldn't be very playable on either GPU.
Reply 5 of 6, by vt86
Nice build.
Makes me miss my old Voodo card from back in the day. Man the things we took for granted, 🤣.
Reply 6 of 6, by NeoG_
Someone is asking 10KUSD on ebay for one of these obsidian x-24 cards
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
