First post, by UCyborg
https://keepandroidopen.org/
Apparently old news, but only recently came across it...
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1 of 12, by Matth79
New to me... and using alt app source is risky and you are warned about it
Reply 2 of 12, by dr_st
Does it mean that it will no longer be possible to publish on the Play Store without all this registration and identification?
Or does it also mean that the option to install a APK manually will be taken away?
What about Developer mode?
Basically, are the additional restrictions only on the publisher's side, or also end-user's side?
If end-user - is this "certified Android device" an optional thing or mandatory? Is open-source Android going away?
Reply 3 of 12, by UCyborg
First part, definitely.
Second, at least so far, certified device was usually the one that didn't have its bootloader unlocked. Though there are varying levels of integrity checks and only the most stringent one requires locked bootloader. Of course, the one with locked bootloader most easily passes all of those.
Reading what they have written certainly gives impression that at the very least the device in typical stock configuration will reject apps not sanctioned by Google.
Reply 4 of 12, by dr_st
It is important to understand what "typical stock configuration" means, and how easy it is to change it.
On any Android phone so far, I can enable Developer mode in a few clicks (this lets me further enable USB debugging and then you can do almost anything, albeit through rather complicated means). There is also a special permission to allow app install from non-default sources.
Which of these will be taken away, if any? If Developer Mode exists, and can be enabled easily, then I could even live with it being a requirement for APK sideload. In fact, it's probably better this way.
Otherwise, it will indeed become iOS's twin - where you have to first 'jailbreak' the phone to gain control over it. Seems stupid and undesirable.
Reply 5 of 12, by theelf
i give up with phones some time ago
Never was much of interest, but i liked windows mobile back on time, and years later, even being very restrictive enjoy BB10
Never liked android, never. Feel slugish and bloat to me.even aosp
But at least wass usable, and i liked to customize, change roms etc
But at the end of day, i use the phone for WORK and FAMILY
And there ir a problem, called... WHATSAPP
Whatsapp never was nice, but since some time ago block and detect unlocked bootloaders and kick you out
end of story
Yes,some people, include myself success to bypass veryfications, but in a working emviroment this is not acceptable, i cannot lost contact with customers one day because whatsapp upgrade and found a way to block me again
and same with bank, goberment stuff etc
Even if android change to aclosed model are app the ones will fuck you before
Reply 6 of 12, by RandomStranger
Matth79 wrote on 2026-03-01, 21:34:
F-droid is safer than the playstore.
Reply 7 of 12, by Ozzuneoj
Bleh. Doesn't really surprise me with the way the rest of the tech industry is going now.
I'm sure some future phone of mine will no longer run the relatively ancient Blokada 5 app (not from the Play store) that I have been using for several years, which blocks most ads in most apps. I hardly do anything on my phone, but when I am on it I do not want to deal with obnoxious advertising.
I help an elderly man with his devices and he has been bombarded with garbage on his phone (Samsung) over the past year because he has trouble discerning between things that are trying to manipulate him and things that he should actually interact with. It got so bad a couple months ago that his phone was just constantly spewing full screen, full-volume tiktok-like videos that were obviously designed to grab the attention of old people and brainwash them into buying things to "protect" themselves. I installed Blokada 5 on his phone and it has been silent ever since. He's not getting any ads, he isn't accidentally installing any malicious apps and he can now use his phone when he needs it without tapping on things that render it unusable.
What is absolutely ridiculous is that *I* had to enable the phone's ability to download apps from outside sources to get Blokada 5. All of the garbage he's been dealing with has come directly from Google Play. Of course, I switched this back off when I was done installing the app... but it's disgusting that such awful apps are promoted on the official store.
One can only hope that when this change happens, it will allow Google to control the malicious ad-filled garbage that plagues their store. But, I'm not going to hold my breath, considering where their money comes from.
I'm just glad I don't do much on my phone any more. From 2011 to 2022 I only used bootloader unlocked and\or rooted Android phones. My current one is locked and not rooted, and it has been okay that way because a lot of things that were locked down years ago have been made usable without root access... but also, I just don't do as much on it as I used to.
Honestly, it's amazing that in 2026 I can still install a device-wide ad blocker, a browser with it's own dedicated ad blocker and a version of Youtube that is mostly ad-free and removes tons of manipulative trash from the app. I guess that could all change by next year, but I will probably be keeping my phone for several more years.
Reply 8 of 12, by the3dfxdude
dr_st wrote on 2026-03-02, 08:31:
Yes, but not exactly the way you say it. An APK can be installed manually, but only if it is signed by a key also authorized by Google. So basically equivalent to a play store app, and will have to phone home and get permission from Google even if you don't use play store.
Identity will have to be shared either way, to get an approved key, play store or not.
I dunno, never used that. Might as well fork android if people have to resort to tricks, because they'll make it harder to get that. Just look at Win11.
Both.
Reply 9 of 12, by RandomStranger
the3dfxdude wrote on 2026-03-03, 19:11:
It's already done. There is LineageOS. I use it on an old tablet that can't go above Android 5 on the factory OS. This way it can get as high as 7.1 with LineageOS 14. Still old, but new enough to run the handful of apps I'm using.
Some more recent devices of course support (are supported with) releases based on more recent Android. LineageOS 23 is based on Android 16. The problem is, you have to choose your phone specifically to run the alternative OS. Not everything is supported and even those that are, opening the bootloader can be a pain in the ass. Like with my old Nokia 7 Plus.
You can find unofficial builds for officially unsupported devices on xdaforums, but they can have issues or you might lose features. I tested one with an SM-T280 tablet and had a lot of stability issues and didn't handle the camera well.
There is also GrapheneOS, but device support is even more limited. Exclusively Pixel phones. CalyxOS that only support a handful of devices besides Pixels. There are also some smaller forks mostly not worth bothering with.
Problem is, for some apps these forks fail device integrity check and won't launch. Also, installing these forks are not as trivial as wiping windows and installing Linux in its place.
Something I have no experience with, it the Chinese forks like Xiaomi HyperOS. These were born out of necessity after Google started to block them from using official Android.
Reply 10 of 12, by ell1e
I like the PinePhone. It's retro too, with rather low end hardware.
Reply 11 of 12, by dr_st
RandomStranger wrote on 2026-03-04, 05:08:
On their native devices they work fine. I don't know if they can be force installed on a different device, or whether they have plans to enforce any kind of lockdown like whatever Google is trying to do.
Reply 12 of 12, by LSS10999
It's already done. There is LineageOS. I use it on an old tablet that can't go above Android 5 on the factory OS. This way it ca […]
Looks like GSIs have become mature enough to run on most modern devices provided you have unlocked the bootloader and can properly access "fastbootd" in the recovery. With recent Android devices utilizing GKI2, chances of successful operation are even higher, and much easier to get root (there are prebuilt KernelSU-included GKI images available).
The question, however, is that whether the device vendor is willing to provide the option for you to unlock. Not all vendors permit unlocking, and a good amount of vendors that used to permit such have stopped doing so.
The whole device integrity check thing (Safety Net) started some point around Android 5/6 IIRC, and it was mostly about corporate requirements, where they have a good reason to ensure no devices within their internal networks are (actually) compromised. In practice, however, this has become a systemic discrimination against those who chose to root their devices, thus the cat-and-mouse game of root hiding keeps on.
IMHO Android can never become iOS performance-wise, no matter the effort. If it ever reaches that point as OP linked, Android will eventually lose all of its appeal, though I can't really imagine what will happen to the ecosystem after that...
PS: Back then when Win11 announced WSA as well as ARM64EC support, on top of existing WSLs, I was thinking about the possibility that Android might be the one actually getting EEE'd instead of Linux, as being able to run Windows x64, ARM64, and Android apps at the same time on a single ARM64 smartphone would be an insane feat that could surely dominate nearly all the non-Apple market share. Sadly M$ has decided to axe it instead of perfect it.
