Reply 380 of 470, by gusG
Dan thanks for fast response.
Weird from my pc I get page not found.
But from mobile phone I can normal enter your site. Maybe the ISP is the problem!
Reply 381 of 470, by Chkcpu
DEAT wrote on 2026-02-18, 21:53:
Chkcpu wrote on 2026-02-15, 21:48:
@DEAT, Okay, one down and one to go. :) Do you have a POST analyzer card to check at what code the Unicore BIOS hangs? […]
@DEAT,
Okay, one down and one to go. 😀
Cheers, Jan
Yep, here is a photo of where the POST card hangs:
The attachment 2026-02-17-19-52-32-424.jpg is no longer available
Hi DEAT,
Thanks fort he POST card photo of the point where the ECS P5ST-BR Unicore BIOS hangs.
This POST_31 is where the Memory test counter is put on the screen and the actual extended memory is tested in Protected Mode.
The previous POST_30 step is where the memory sizing is done. Seeing POST_31 on the analyzer card, we know POST_30 was completed and POST_31 was started by the BIOS.
Looking at the beginning of the POST_31 BIOS code, I see some instructions to setup the memory counter and loading the memory size as found in POST_30.
Then the “Press DEL to enter SETUP” line at the bottom of the screen is appended with “, ESC to skip memory test”, followed by displaying the Memory test counter itself just below the CPU Type line.
In your case, these text lines are not displayed, so the BIOS hangs before that during the setup code. I will look into the original P5ST-BR BIOS to see what is done differently here.
In the mean time, can your try the Unicore BIOS again and see if this works:
- Reduce the FSB to 75 or 66MHz.
- Limit the amount of RAM to 64 or 32MB
- Use another CPU, like a Pentium MMX or WinChip 2
Then one last question, can you still enter the BIOS Setup during the POST_31 hang?
Greetings, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 382 of 470, by NeoG_
Chkcpu wrote on 2026-01-07, 18:26:
Hello Mad_Wolf,
Yes, I will send you the patched MD-4DUV(C) VER 3.1 BIOS via PM for you to test.
Cheers, Jan
Hi Jan,
I have an Acorp 5ALI61 with Award 4.51PG BIOS, it has 128GB HDD and K6+ support so I thought the bios is pretty recent. I think it is affected by a UDMA issue since the HDD and SD-IDE adapter are advertising UDMA5 but the drives are stuck in MWDMA2 mode. I wanted to ask if the Redfox AGP-ALI BIOS on your website in the patched BIOS section would have a fix for this issue?
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 383 of 470, by Chkcpu
NeoG_ wrote on 2026-02-25, 11:55:
Hello Mad_Wolf,
Cheers, Jan
Hi Jan,
Hi NeoG_,
Do you run a 1Mbit VER:1.4 or VER:1.5 BIOS on your 5ALI61, or a 2Mbit VER:2.2 or VER:3.3 BIOS?
I’ve checked these four BIOS versions and they all support UDMA correctly. So no UDMA mode bugs in any of these BIOSes.
You should see UDMA33 or ATA33 indicated on the BIOS summary screen for any UDMA2 or faster drive. If so, your issue is not a BIOS issue.
Note that there are boards with the M1543C-B1 southbridge that can do UDMA4, but you need a 2Mbit Flashchip and the VER:3.3 BIOS to support that. Boards with the M1543C-A1 southbridge are limited to UDMA2 and can use one of the above 1Mbit or the 2Mbit VER:2.2 BIOS.
Cheers, Jan
Reply 384 of 470, by adegn
I've been searching for weeks now for a solution to my issue - I really hope someone can help me with some hint.
My award 6.00pg and 4.51pg bios'es reject loading an expansion ROM for the a via sata adapter. It doesn't work from the adapters onboard ROM - and also not when the ROM is included in the BIOS. Adding the same ROM to another socket super 7 motherboard with Ami bios works fine.
So I found an answer in a forum, describing some filtering on which PCI ven/dev are allowed for expansion ROM loading. Unfortunately I can't find that forum article anywhere again.
Does any of you know about a filter that will only allow specific expansion ROMs? And if yes - have you got a hint for me on where to look for this "whitelist" function?
Kind regards
Anders
Reply 385 of 470, by NeoG_
Chkcpu wrote on 2026-02-25, 19:19:
Hi NeoG_, […]
Hi NeoG_,
Cheers, Jan
It is running VER: 1.5 dated 2001, I believe this is the unpatched 1MBIT beta bios available on your page (It was flashed by the seller before sending to me). The strange thing is that the BIOS is always complaining about lack of 80 wire cables on primary and secondary channel. This shouldn't matter with a UDMA33 controller, and also plugging in 80 wire cables doesn't make the message disappear, maybe this is just a quirk of a later bios that is aware of UDMA>2 as I didn't think UDMA33 was even 80 wire aware. I was able to confirm the drives can operate in UDMA using a SIL0680 PCI controller in the same computer with higher speed and lower CPU usage. But I was hoping not to use the extra PCI slot, the chassis is quite full.
The BIOS data page which shows before boot does say the drives are UDMA33/LBA, however in both DOS and windows the transfer speed is limited to less than 16MB/s and CPU usage is higher than expected. This lines up with HDAT2 reporting the UDMA devices operating in MWDMA2 mode. HDAT2 is also unable to send the ATA command to change transfer mode.
It is a bit of a head scratcher.
Reply 386 of 470, by DEAT
Chkcpu wrote on 2026-02-24, 10:29:
Hi DEAT, […]
Hi DEAT,
Greetings, Jan
Thanks for the response - I only just got around to testing now. I already have 64MB of RAM installed, I don't have any smaller sticks of SDRAM.
Reducing the FSB to 66 did nothing, neither did using a Pentium MMX. I can't enter the BIOS setup at any stage of the boot process.
win16.page | Twitch
Reply 387 of 470, by Chkcpu
DEAT wrote on 2026-02-28, 07:51:
Hi DEAT, […]
Hi DEAT,
Greetings, Jan
Hi DEAT,
Well, this Unicore BIOS appears to be incompatible with your ECS P5ST-BR. 🙁
Fixing the original BIOS is another solution, I assume your board runs fine on the original BIOS?
I only see one ECS P5ST-BR BIOS on TRW, is it this Ver. 0.9 (04/09/98) that’s on your board now?
And which fixes are you looking for in the BIOS?
This BIOS is now nbr. 5 on my “to be patched” list , so it will take some time before I can start working on it.
Cheers, Jan
Reply 388 of 470, by DEAT
Chkcpu wrote on 2026-03-05, 16:06:
Hi DEAT, […]
Hi DEAT,
Cheers, Jan
Yep, I had submitted the BIOS to TRW from my board. 128GB and K6-3+ support are the main fixes, not sure what other fixes are applicable.
win16.page | Twitch
Reply 389 of 470, by evanboonie
Chkcpu wrote on 2026-02-18, 10:58:
Hi evanboonie, […]
Hi evanboonie,
I was able to invest some more time in patching the AMI BIOS for your Apple 1997 PC Compatible Card.
I’m happy to report it is finished now, almost 4 months after your initial request. 😉
I patched the original BIOS8.ROM you sent, and here is a copy of this Patch J.1 version:
The attachment Apple_Viper_J1.zip is no longer available
I’ve added support for the 2.2V K6 model 7, K6-2, K6-III, K6-2+, and K6-III+. I’ve also expanded the K6 Write-Allocation feature to work on the K6-2(+)/III(+) models with CXT core.
I was unable to change the CPU speed display logic for these faster K6 models, so you may see some funny speed indications when going above 233MHz.
I’m very curious what you get when testing with a K6-2(+)/III(+) CPU. Hopefully there is no other hardware or software component that prevents these CPUs from running.
Happy testing!
Jan
Thanks so much, Jan! Things got pretty chaotic there for a while on my end and I haven't had time until this weekend to test it out. Unfortunately, I could not get a K6-2/333AFR (clocked at 280MHz) working with this BIOS, but it did still work with the original 3.2V K6/233 Model 6 (also at 280MHz). I was using a different voltage interposer and an untested CPU, so I'm going to try a known working 500MHz K6-2 next week. It just takes me a while to swap CPUs since I have to use a temporary adhesive like hot glue to hold the heat sink on when using the interposer, as it doesn't have its own heat sink clips.
I am also going to start working on an ISA breakout card that hangs off of the "XD expansion" port and uses the Mac PCI for power. That should allow me to plug a POST analyzer card into the PC compatibility card and see if any POST codes show up. I'll post back here as I try different things out and make progress.
Reply 390 of 470, by evanboonie
Today I validated that the voltage on the second interposer was working properly and taped a heat sink on to a known working K6-2/500AFX for further testing. Unfortunately, that CPU is also not working in the PC card. The card is still detected and the video switches over, but no video output ever comes up like its getting stuck in POST somewhere.
Reply 391 of 470, by Chkcpu
DEAT wrote on 2026-03-06, 06:52:
Hi DEAT, […]
Hi DEAT,
Cheers, Jan
Hi DEAT,
The patched Ver 0.9 BIOS for your ECS P5ST-BR is ready, and here is a copy.
In the zip, you will find a PATCH.TXT file that lists the changes I’ve made.
The attachment P5STBRJ2.zip is no longer available
I expect that this BIOS will work better than the Unicore BIOS I sent before. 😉
Depending on the CPUs you have at hand, I would like to know how the patch J.2 BIOS reports them. Due to the changes I’ve made, I’m specifically interested in the K6-2, K6-III, K6-2+/III+, and WinChip 2(A)(B).
In addition, IDE drives up to 128GB should work fine now.
What surprised me with this BIOS is that it doesn’t have any UDMA support, although the SiS-5582 chipset supports it. So only PIO mode 4 and MWDMA mode 2 on this board, just like on i430VX and i430HX chipsets.
It looks like UDMA has been omitted on purpose. Do you know if this is an industrial board? A Socket 7 board with 8 ISA slots but zero PCI slots is quite remarkable!
Happy testing, Jan
Reply 392 of 470, by myne
Hi Jan,
Might need your help. Dumped this from an interesting little chinesium board. Amibios8. Can't seem to find any version of amibcp that opens it.
I believe based on this bios string 64-0100-000001-00101111-081718-lfdhvdimc-BU55R105
It is a hacked Dell Studio 8100
https://www.bios-mods.com/forum/archive/index … read-28261.html
Which opens fine (image below)
Indiafix has different "working versions" but they seem to be shall we say "borrowed" from different boards and I don't have a CH341a handy to risk it.
https://www.indiafix.in/2023/12/bios-bin-zx-h … 41-zx-h55m.html
Dump = $BTSBU55R105 0 êªÿ ð08/17/18
"1.01"=$BTSZP55M000 #) êªÿ ð10/18/17
"1.11"$BTSH55MR103 C8 êªÿ ð03/05/18
"1.41"=$BTSH55MR306 X êªÿ ð06/18/19
It's an interesting board. Insanely cheap, and I managed to install 98 on it on USB by forcing it to HDD emulation, and usb2 so 98 didn't try take it. (don't want to delete any of my sata drives)
Going to test HDA on 98 next HD Audio Driver for Windows 98se / Me / 2000 / XP
Any ideas?
I built:
Reply 393 of 470, by Chkcpu
Hi myne,
I never had to tinker with BIOSes from these “modern” systems, so my expertise in this area is zero. Sorry I can’t help you with that.
I’m much more interested in older systems and BIOSes from the 1993-2002 era, so that’s why I focussed my BIOS patching hobby on Socket 3/5/7/Slot 1 boards.
Cheers, Jan
Reply 394 of 470, by myne
Ah. Bummer.
I built:
Reply 395 of 470, by Disruptor
Chkcpu wrote on 2026-04-28, 13:12:
Hi myne, […]
Hi myne,
Cheers, Jan
That's fine, Jan.
It matches my region of interest too.
Perhaps I'd add Socket 370, but this is litereally the same as Slot 1.
Reply 396 of 470, by myne
Time is inevitably ending many old things.
The first gen cores are right on the edge between old bios and uefi.
I figured if anyone knew, it'd be Jan.
I built:
Reply 397 of 470, by sizzlinbeef
dm- wrote on 2025-03-24, 03:10:
Hello Jan! […]
Hello Jan!
I got another nice early ATX board MSI MS-5136 TR8
https://theretroweb.com/motherboards/s/msi-ms … 136-ver-1.0-tr8
The board has an undocumented 2.2v setting so i inserted amd k6-2 cpu -)
Any chance you can share/document the undocumented 2.2v vcore jv1-8 setting? I have this same board and a k6-2 to try with the updated bios.
Reply 398 of 470, by Chkcpu
sizzlinbeef wrote on 2026-05-07, 00:11:
Hello Jan! […]
Hello Jan!
Hi sizzlinbeef,
Did you already find-out what the undocumented 2.2V setting is on the MS-5136?
If not, and if you have a multimeter, I can help you with a procedure to test what the undocumented JV6/JV7/JV8 jumper settings do.
However, this MS-5136 board uses a linear voltage regulator for the Vcore supply, which already gets very hot when using a Pentium MMX 233. A K6-2 draws a lot more current and can quickly overheat and burn the regulator.
A K6-2+ is a lot more energy efficient and may work here. But for that we need to find an undocumented 2.0V or 2.1V setting. 😉
Greetings, Jan
Reply 399 of 470, by sizzlinbeef
Chkcpu wrote on 2026-05-27, 17:44:
Did you already find-out what the undocumented 2.2V setting is on the MS-5136? If not, and if you have a multimeter, I can help […]
I did not find out the settings. I do have a multimeter and would be willing to figure them out with your help so we can have them for posterity. I don't have a k6-2+ or 3+ unfortunately so it'll just be an information gathering exercise if you think the board would be at risk with my regular k6-2.
