First post, by justin1985
I'm setting up what I hope to be a my main Win98 and DOS gaming PC, using a Chaintech VIA KT133 based early Socket A board (with ISA). I've also found a nice Silverstone mATX case that actually has 2 x 3.5" external drive bays, and I want to use them for one standard 3.5" Floppy as well as a Gotek, for flexibility and to make disk images etc.
The BIOS on the board definitely supports 2 floppy drives, including having a "swap floppy drive" option (which works), and reports them as A and B in the system summary table at boot. If I boot using a DOS boot disk, the two drives are correctly identified as A and B.
But when I'm booted into Win98SE, the second floppy drive is always reported as drive E: ! (after the two HDD partitions, but before the DVD drive). I guess this isn't the end of the world, but it does bug me, and means I have inconsistent drive letters whether booted to Windows or DOS. Windows Device Manager doesn't give the option to reassign the second floppy's drive letter. Is it being set by a config file somewhere else?
