New Old PC -- Windows 98SE or Windows XP?
First post, by LordLao74
Hey all,
I just got a new old Dell to play with and I'm trying to decide in which direction I'd like to take it. Figured I'd come here for some fun discussion on the topic.
Currently, the Dell has a Socket 478 motherboard with a Prescott Pentium 4 HT 3.0GHz, 512MB DDR-400, integrated audio (probably Realtek, haven't checked), an Intel Extreme Graphics 2 IGP. As it is, the system feels better configured for Windows 98SE where the IGP won't be totally useless. I also don't currently have a reliable Windows 98SE system. I have a Slot 1 Pentium III but it gives me endless software issues (multiple windows reinstalls no idea what its deal is) and my other Windows 98 socket 370 system has been down so long I can't even remember what's wrong with it. For these reasons, I'm sort of tempted to toss Windows 98 on it.
At the same time it'd be fun to upgrade it too into a better Windows XP system. This motherboard lacks an AGP or PCIe slot so PCI is the only option for add-on cards, but I have a PCI ATI Radeon 9250 I could install and I could bump the RAM up to 2GB (only two RAM slots). Probably won't add a sound card to save time on the PCI bus for the GPU. This would let me use the HT features of the processor, which I doubt work well on Windows 98 so I'll likely disable Hyper-Threading if I go the Windows 98 route.
I already have a solid Windows XP system with a Core2Duo E8500 CPU, 4GB RAM, and a GTX 645 GPU. That system is very capable so keeping this one WinXP doesn't really permit me to play anything I couldn't already run on the other system. So I feel like I will end up running games that are more inline with 98 like Monkey Island, Starcraft, Diablo. Most demanding game I'm likely to throw at it is something like Star Wars KOTOR II.
Thanks for your thoughts
Reply 2 of 28, by LordLao74
That is what I'm leaning more towards at the moment. Might add a sound card if I do go Win98 but otherwise its all set after I apply some new thermal paste.
Reply 3 of 28, by NeoG_
I would normally say ¿por qué no los dos?, but since you already have a capable XP system I don't see any reason to have another P4 XP system. Would serve you much better as a 98SE system.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 4 of 28, by LordLao74
That's my feeling too. So I'm installing Windows 98 as I type this. So far so good. It would be really cool to have a stable Win98 system again.
I think part of my hesitation to move off XP was that this thing still had its original install of Windows XP from whatever year this thing was bought with the serial key on the side of the case. Felt almost wrong to remove it after so many years. Also the parts I could have added are just sitting doing nothing and that's no fun. But I do miss Win98
Reply 5 of 28, by NeoG_
Since you aren't using it, may as well stick the 9250 PCI in there anyway. It works with 98SE.
Reply 6 of 28, by Twisted Six
I'll swim against the stream....I hated all the DOS-based versions of windows from W311 up through ME. WHen I gave up DOS I went to WinNT4 and never looked back. All the games we played ran swell on it and 3DFX always supported it. It was fun laughing hysterically at all the other silly ones cussing their unstable Win9x systems; especially if it crashed in the middle of gameplay!! Networking sucked...security sucked....everything sucked...so I'd vote XP. If you want some nostalgia, OK, Win2k; probably my favorite retro OS...infact I'd still be running it if there was browser support! Any prescott P4 system will have Win2k support along with XP.
Ok you win98 brats, throw rotten tomatoes!! 😜
If you tolerate this, then your children will be next.
Reply 7 of 28, by wbahnassi
XP would be the suitable one for a P4, but what the heck... I like to know that I can go for anything but the norm, esp. if I have another system with the same OS. So I'd say go with anything else but WinXP 😅
I, too, am of the Win2K fan-base... I'd say it's probably time to give it a shot.. or any other OS for that matter.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 8 of 28, by RetroPCCupboard
I think mostly things that work on Win2k will also work on your XP box. And you mentioned that both of your win 98 boxes have issues. So I would install Win98. Possibly adding a PCI soundcard that is compatible with MSDOS if you want to venture into that territory.
Reply 9 of 28, by LordLao74
Thanks for the replies everyone. I went ahead to install Windows 98SE with the hope of getting a functional Win98 system to enjoy. So far its been a fairly typical Windows 98 experience...which of course means problem after problem after problem 🤣.
These parts came inside of a Dell Dimensions 3000 desktop that the previous owner appears to have hardly used. (BIOS error log shows an event in 2005, a couple in 2011, and one in 2021) Dell doesn't have any Windows 98 drivers that I can find so I'm working on sourcing drivers for the individual chips. I attempted to run Unofficial Service Pack 3.66 and that failed, then 3.56 and that also had issues probably due to the 3.66 failed install. Ended up doing a second clean install of the OS. I was trying to do that for USB support to make getting files on the system a bit easier, but now I've got my USB DVD burner out to transfer files via disc instead for the moment.
Currently held up trying to fix the graphics that is reporting the device cannot find any free input/output range resources to use. I don't have any PCI devices installed aside from an old telephone modem that I've left for the moment just to fill the hole in the back of the case, so this is a bit weird. Gonna keep fussing with it, but Windows XP does start to feel alluring fast. Any tips on how to get over this issue would be appreciated. I don't think disabling the Intel Extreme Graphics and switching to the Radeon 9250 would fix it or I'd try that.
For those suggesting I try Windows 2000, I respect your choice to use that OS as it does have its own place in OS history, but it just doesn't appeal to me. Where Windows XP in my opinion is more or less a better version of the same thing, and I have more nostalgia for it, I'd lean into XP first if change back off of WIn98.
Reply 10 of 28, by LordLao74
Actually I fixed the resource conflict issue I think, not getting an error now. Got the chipset and Intel Extreme Graphics 2 drivers installed as well as nusb that has flash drives working (thank god!). Now just got to wait while everything transfers and to find the audio driver. So this also feels very typical Win98 for me. Can hit tons of issues but when stuff starts working sometimes they all just start to vanish 😀
Reply 11 of 28, by NeoG_
Always will be a bit of a struggle when using hardware that was not scoped for a particular OS. But you can wrangle it into working.
Reply 12 of 28, by leileilol
Given it's closer to the P4 era, I'd Me it up.
Reply 13 of 28, by Jo22
leileilol wrote on 2026-03-08, 01:03:
When I started reading I was going to say that, too! 🙂
Or maybe, NUSB or one of these unofficial Service Packs will do?
I'm not that much of a fan of those modifications, but they do include the better parts of Me only.
These newer 9x system files might be more suited to Pentium III or IV era systems.
NeoG_ wrote on 2026-03-08, 00:41:
Indeed. But I think Windows 98SE and XP are like siblings in some way.
They're from about same era and both focus on then-new WDM drivers.
Windows 98SE had a very balanced VXD/WDM support,
while Windows 2k/XP moved away from Windows NT 4 driver model and torwards WDM.
In reverse, 98SE had ntkern.vxd, to support a subset of Windows NT functions.
So chances are good WDM device drivers of the era will work on both platforms.
Because they're either using same feature set or compiled from same source.
What's good about Windows 98SE is support for ISA cards (Plug&Pray and non-Plug&Pray), DOS and Windows 3.x drivers.
It also allows applications direct hardware access via i/o ports etc.
That's useful for games using gameport, OPL3 or PC speaker directly or useful to electronic hobbyists.
Windows NT/2000/XP needs PortTalk to allow that.
Windows XP by contrast is often very smooth, even though a bit slower on same hardware.
The GUI nolonger is fully hardware-accelerated due to use of GDI+, which needs a bit of assistance by the CPU.
(That's generally the case of GDI+ applications, I think, even if run on Windows 9x by help of gdiplus.dll.)
That doesn't mean that blitting and GDI acceleration is gone, no,
just that GDI+ applications demand for more than plain GDI graphics primitives that are handled solely by 2D GDI drivers.
The absence of GDI acceleration, say through use of old dumb ISA VGA cards, does impact XP's performance (peaks in task manager).
Anyway, long story short, focusing on a good Windows 98SE config doesn't hurt (3D accelerators, network cards etc).
If Windows XP is eventually used on same specs (dual boot?), chances are good it will recognize most 98SE components just fine.
Merely DOS or ISA stuff might be an uncertain factor.
Most ISA VGAs, ISA network cards or 16-Bit ISA Sound Blasters will be detected, though.
There's an WDM driver for Sound Blaster 16/32/AWE, I remember. It's been used under Virtual PC, for example.
It's for the Plug&Pray versions, but might be usable for non-PnP versions, too.
The Gameport and MPU-401 is still being supported, too.
Reply 14 of 28, by LordLao74
I haven't tried to run Windows ME since it was new. How is it in terms of stability? I might give it a try cause I'm about to give up on Win98.
I really want a well working Win95/98 system partially for nostalgia as that's what I grew up with. I went for Win98SE hoping for best stability, and trying slightly newer hardware hoping to prolong the system's life and hopefully avoid issues due to older failing hardware a bit. I figured P4 hardware would work well as it came out just a few years after WIn98SE but that's just not going well. I managed to fanagle the Extreme Graphics 2 into working, and I have NUSB installed that has flash drives working. Haven't had any luck getting the integrated audio chip to work (Analog Devices ADI 198x). I have a Dell distributed driver for it that includes a Win98 folder and what looks like all the files it should need, but the setup fails and manually selecting the folder with the driver files using Device Manager ultimately fails too. It starts to work, says its building driver database, but then hits a wall. I might just give up on it and throw in a PCI sound card of some sort as I have a couple, but not the only issue.
Part of why I want this is also to boot into MS-DOS mode to run click-adventure titles and hear the music played on the motherboard spear, because I like hearing it that way. I know an older PC would be better for that but I don't think any of the click-adventure titles are impacted by too fast hardware. Anyway, I can get Monkey1 to start, but no audio and no beeping from the motherboard speaker. Can't get Monkey Island 2 to start yet. Actually I'm typing this right now while the system is hung up trying to boot into DOS mode.
Other games like Diablo have worked fine so far, but those work just as happily in WinXP and going on the third day of trying to get this working so I'm tempted to just go XP so I can enjoy my games instead of spending all of my free time troubleshooting. (Which is very limited as my wife and I just had a baby and I start back to work tomorrow). So I may give up and just do XP. Most fun I've had with 98 so far is looking at the old screensavers. Can always try to run these DOS games off a CD while booted into a DOS on a different CD, done that before. Appreciate all the suggestions
Reply 15 of 28, by maxtherabbit
I'd always vote for XP when it's hardware which will run it well. Genuinely goated retro windows
Reply 16 of 28, by LordLao74
maxtherabbit wrote on 2026-03-08, 18:36:
Yeah, I suppose I shouldn't be trying to force the system to run an older OS. I'm reinstalling XP now.
Couldn't find where I've put my Radeon 9250 PCI card, probably in another system around here somewhere. Instead I tossed in an Nvidia FX 5200 PCI and gave it the RAM upgrade to 2GB. So should make a fun little XP system anyway and just run all the same games just no DOS mode without a CD. Can live with that.
Reply 17 of 28, by Errius
As others have said, for this kind of hardware ME is better than 98. In my experience, ME includes drivers for everything except GPU, while 98 requires you to hunt around for audio/Ethernet/USB and possibly other drivers.
(I have a machine with similar specs that dual boots ME and XP. Video card is a GeForce4 MX.)
"AI Requires Proof That You Are Human"
Reply 18 of 28, by Harry Potter
I have a Win98SE tower at my mother's house--anyway, I did, until she went homeless--and was having a nightmare getting it set up, but, in the end, I managed. My system would only work properly with the UMBPCI Upper memory manager. There were also other problems. I think removing a reference to SETVER in config.sys also helped. As far as it being worth it, barely, but at least I have a working Win98SE tower now. 😀
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 19 of 28, by cyclone3d
Jo22 wrote on 2026-03-08, 06:50:
When I started reading I was going to say that, too! 🙂 […]
The unofficial service pack will jack stuff up.
NUSB for the USB storage.
Use the 2004 Microsoft Update CD to update Windows. It is available on vogons drivers.
For chipset drivers, there are modded drivers available so stuff show up right in Device manager.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
