First post, by Speedwarrior956
It Goes like this: Whenever i try to install this game on my #WarMachine -either fron the game's launcher or its installer suite-, it hangs up on me nearing completion -about 98% give or take- with a weird error popup message. No matter which compatibility mode i'd choose (Apparently it runs on either Windows Vista or 7.), it keeps undoing the instalation process every single time What could it be? #PleaseHelp
Reply 1 of 3, by Hezus
When Operation Flashpoint was renamed to ArmA1, Bohemia released an updated installer. That one has been working great for me, even on Windows 10 and 11. You can probably find it with a little googling. You can then use the CD key from your Operation Flashpoint case.
Visit my YT Channel!
Reply 3 of 3, by Speedwarrior956
I've already tried that....and it definitely worked for me.
BTW It appears to be listed on its PCGW entry as an official "title" update to *Operation Flashpoint* (v1.99 Patch if i'm not mistaken.)
All i need to do is to find a good strategy guide and a proper EAX Restoration Patch for it to enable that setting properly and enjoy it to the fullest....
(It appears to be lackin' quite a bit on the latter though....)
