Duke07 - another MS-DOS port of Duke3D
Reply 40 of 51, by Darkcrafter07
analog_programmer wrote on 2025-08-12, 07:28:
Thanks for the clarification! If I understand correctly, when "ydetail" variable in "ENG386.C" is set to 3, the produced executable will be for even lower details.
I have a suggestion. For easier compiling and linking of different executable versions you can separate make-files and altered .C and .H files in separate folders like "D07_SRC", "D07_SRC_LQ2" and "D07_SRC_LQ3".
Not yet sir, let it be like that.
What I've been trying to do for more than 4 months is getting a non-fpu version of slopes drawing to work. There's a version that finally doesn't crash and does perspective correction, yet faster on a nonfpu SX processor, it still looks awful and coming with a lot of geometric distortions.
a part from A.asm:
BITSOFPRECISNLQ equ 3
BITSOFPRECISNLQPOW equ 8
ALIGN 16
PUBLIC setupslopevlin2_
setupslopevlin2_:
mov dword ptr [slopmach3b+3], ebx ;ptr
mov dword ptr [slopmach5b+2], ecx ;pinc
neg ecx
mov dword ptr [slopmach6b+2], ecx ;-pinc
mov edx, 1
mov cl, al
shl edx, cl
dec edx
mov cl, ah
shl edx, cl
mov dword ptr [slopmach7b+2], edx
neg ah
mov byte ptr [slopmach2b+2], ah
sub ah, al
mov byte ptr [slopmach1b+2], ah
; FPU removal: Convert floating-point init to integer scaling
; Original: fild _asm1 + fstp _asm2
mov eax, [_asm1]
;shl eax, 16 ; not needed now
mov [_asm2], eax
ret
ALIGN 16
PUBLIC slopevlin2_
slopevlin2_:
mov _ebpbak, ebp
mov _espbak, esp
sub ecx, esp
mov dword ptr [slopmach4b+3], ecx
mov ebp, eax ; Remove FPU load
slopmach6b: lea ebp, [eax+88888888h]
add ebx, dword ptr _asm2 ; Replace FPU add with integer op
mov _asm1, ebx
shl ebx, 3
mov eax, _globalx3
mov ecx, _globaly3
imul eax, ebx
imul ecx, ebx
add esi, eax
add edi, ecx
mov ebx, edx
jmp short bigslopeloopb
ALIGN 16
bigslopeloopb:
Show last 58 lines
	mov dword ptr _fpuasm, ebx              ; Replace FPU store
mov eax, ebx ; Modified from original FPU path
add eax, eax
sbb edx, edx
mov ecx, eax
shr ecx, 24
and eax, 00ffe000h
shr eax, 11
sub cl, 2
mov eax, dword ptr _reciptable[eax]
shr eax, cl
xor eax, edx
mov edx, _asm1
mov ecx, _globalx3
mov _asm1, eax
sub eax, edx
mov edx, _globaly3
imul ecx, eax
imul eax, edx
cmp ebx, BITSOFPRECISNLQPOW
mov _asm4, ebx
mov cl, bl
jl short slopeskipminb
mov cl, BITSOFPRECISNLQPOW
slopeskipminb:
mov ebx, esi
mov edx, edi
beginnerslopeloopb:
slopmach1b: shr ebx, 20
add esi, ecx
slopmach2b: shr edx, 26
slopmach7b: and ebx, 88888888h
add edi, eax
slopmach5b: add ebp, 88888888h
slopmach3b: mov dl, byte ptr [ebx+edx+88888888h]
slopmach4b: mov ebx, dword ptr [esp+88888888h]
sub esp, 4
dec cl
mov al, byte ptr [ebx+edx]
mov ebx, esi
mov [ebp], al
mov edx, edi
jnz short beginnerslopeloopb
mov ebx, _asm4
sub ebx, BITSOFPRECISNLQPOW
jg short bigslopeloopb
mov esp, _espbak
mov ebp, _ebpbak
ret
the parts of engine.c:
long reciptable[2048], fpuasm, fpuasmnonfpu;
long reciptablenonfpu[2048], deltaztable[2048];
#define FIX16_SHIFT 14 // Matches Build's 30-bit fixed-point
#define FIX16_FACTOR 0x40000000 // 1<<30 in 32-bit (1073741824)
#define RECIP_TABLE_OFFSET 2048
#define F1_0 0x10000 // 16.16 fixed-point scaling
loadtables()
long i, fil;
float z, dz, nextz, deltaz;
if (tablesloaded == 0)
initksqrt();
// Generate original FPU-based reciptable at all times (it's int too)
for(i = 0; i < 2048; i++)
reciptable[i] = divscale30(2048L, i+2048);
if ( (use_fpu) == 0)
// Generate non-FPU reciptable if nofpu parameter was passed
reciptablenonfpu[0] = F1_0 / RECIP_TABLE_OFFSET;
for(i = 1; i < 2048; i++)
//reciptablenonfpu[i] = FIX16_FACTOR / (i + RECIP_TABLE_OFFSET);
reciptablenonfpu[i] = F1_0 / i;
z = 1.0f; // initial Z (matches original FPU setup)
dz = 0.01f; // step size (adjust based on your needs)
for (i = 0; i < 2048; i++)
// match max line height
nextz = z + dz;
// hyperbolic step
deltaz = (1.0f/z) - (1.0f/nextz);
// convert to fixed-point
deltaztable[i] = (long)(deltaz * (1 << 16));
z = nextz;
// Load built-in tables (sintable, radar angles, fonts)
if ((fil = kopen4load("tables.dat", 0)) != -1)
// Reciptable is NOT loaded from file - generated above
kread(fil, sintable, 2048 * 2);
kread(fil, radarang, 640 * 2);
for(i = 0; i < 640; i++) radarang[1279 - i] = -radarang[i];
kread(fil, textfont, 1024);
kread(fil, smalltextfont, 1024);
kread(fil, britable, 1024);
kclose(fil);
Show last 6 lines
tablesloaded = 1;
I think the biggest challenge is this line: add ebx, dword ptr _asm2
because as soon as FPU addition is removed it breaks the "hyperbolical continuity" as AI said. There are two lines like this in the asm code and I even tried to simulate it with deltaztable yet without much success.
Maybe somebody knows it better.
Reply 41 of 51, by Darkcrafter07
So we're almost there on non-fpu slopes, I think it still looks meh but much closer to the result I'd desire to have. You can download the compiled exe to see how it's going. My further attempt would be to try decreasing "amplitude" of ebx _asm2 additions. It's slower than low detail degraded version but much faster than fully detailed fpu version on 486sx. Later we could combine both approaches and do fully integer slopes in 2x detail loss instead of 8x or even keep it as is. If it goes fine for sure.
Part of A.asm:
EXTRN _surfx : dword
EXTRN _surfy : dword
EXTRN _slopedastat : byte
ALIGN 16
setupslopevlin2_:
neg ecx
mov edx, 1
mov cl, al
shl edx, cl
dec edx
mov cl, ah
shl edx, cl
neg ah
sub ah, al
mov eax, [_asm1]
mov [_asm2], eax
ret
ALIGN 16
PUBLIC slopevlin2_
slopevlin2_:
; Save critical registers
push ebp
push esi
push edi
push ebx
; Surface type check (ceiling(0) vs floor(1))
cmp byte ptr [_slopedastat], 0
jz slp2drawasusual ; Skip inversion for ceilings
; Only invert for floors (dastat=1)
neg dword ptr [_asm3]
neg dword ptr [_globalx3]
neg dword ptr [_globaly3]
slp2drawasusual:
mov _ebpbak, ebp
mov _espbak, esp
sub ecx, esp
Show last 81 lines
mov _asm1, ebx
shl ebx, 3
mov eax, [_globalx3] ; Proper dereference
mov ecx, [_globaly3] ; Proper dereference
imul eax, ebx
imul ecx, ebx
add esi, eax
add edi, ecx
mov ebx, edx
ALIGN 16
bigslopeloopb:
add eax, eax
sbb edx, edx
mov ecx, eax
shr ecx, 24
and eax, 00ffe000h
shr eax, 11
sub cl, 2
shr eax, cl
xor eax, edx
mov edx, _asm1
mov ecx, _surfx
mov _asm1, eax
sub eax, edx
mov edx, _surfy
imul ecx, eax
imul eax, edx
add ebx, 1
mov _asm4, ebx
mov cl, bl
slopeskipminb:
mov ebx, esi
mov edx, edi
beginnerslopeloopb:
add esi, ecx
add edi, eax
sub esp, 4
dec cl
mov ebx, esi
mov [ebp], al
mov edx, edi
mov ebx, _asm4
mov esp, _espbak
mov ebp, _ebpbak
pop ebx
pop edi
pop esi
pop ebp
ret
Part of engine.c:
#define BITSOFPRECISNLQ 3
long SCALEFACTOR = 15; // extra precision
long surfx, surfy, surfstepx, surfstepy, surfz, surfstepz;
long surfx_prev, surfy_prev;
char slopedastat;
grouscan_nonfpu (long dax1, long dax2, long sectnum, char dastat)
long i, j, k, l, m, n, x, y, dx, dy, wx, wy, x1, y1, x2, y2, daz;
long daslope, dasqr;
long dashade, shoffs, shinc, m1, m2, *mptr1, *mptr2, *nptr1, *nptr2;
walltype *wal;
sectortype *sec;
sec = &sector[sectnum];
slopedastat = dastat; // pass to asm to draw ceilings-floors differently
if (dastat == 0)
if (globalposz <= getceilzofslope(sectnum,globalposx,globalposy))
return; //Back-face culling
globalorientation = sec->ceilingstat;
globalpicnum = sec->ceilingpicnum;
globalshade = sec->ceilingshade;
globalpal = sec->ceilingpal;
daslope = sec->ceilingheinum;
daz = sec->ceilingz;
else
if (globalposz >= getflorzofslope(sectnum,globalposx,globalposy))
globalorientation = sec->floorstat;
globalpicnum = sec->floorpicnum;
globalshade = sec->floorshade;
globalpal = sec->floorpal;
daslope = sec->floorheinum;
daz = sec->floorz;
if ((picanm[globalpicnum]&192) != 0) globalpicnum += animateoffs(globalpicnum,sectnum);
setgotpic(globalpicnum);
if ((tilesizx[globalpicnum] <= 0) || (tilesizy[globalpicnum] <= 0)) return;
if (waloff[globalpicnum] == 0) loadtile(globalpicnum);
wal = &wall[sec->wallptr];
wx = wall[wal->point2].x - wal->x;
wy = wall[wal->point2].y - wal->y;
dasqr = krecipasm(nsqrtasm(wx*wx+wy*wy));
i = mulscale21(daslope,dasqr);
wx *= i; wy *= i;
globalx = -mulscale19(singlobalang,xdimenrecip);
globaly = mulscale19(cosglobalang,xdimenrecip);
globalx1 = (globalposx<<8);
globaly1 = -(globalposy<<8);
i = (dax1-halfxdimen)*xdimenrecip;
globalx2 = mulscale16(cosglobalang<<4,viewingrangerecip) - mulscale27(singlobalang,i);
globaly2 = mulscale16(singlobalang<<4,viewingrangerecip) + mulscale27(cosglobalang,i);
globalzd = (xdimscale<<9);
Show last 131 lines
	globalzx = -dmulscale17(wx,globaly2,-wy,globalx2) + mulscale10(1-globalhoriz,globalzd);
globalz = -dmulscale25(wx,globaly,-wy,globalx);
if (globalorientation&64) //Relative alignment
dx = mulscale14(wall[wal->point2].x-wal->x,dasqr);
dy = mulscale14(wall[wal->point2].y-wal->y,dasqr);
i = nsqrtasm(daslope*daslope+16777216);
x = globalx; y = globaly;
globalx = dmulscale16(x,dx,y,dy);
globaly = mulscale12(dmulscale16(-y,dx,x,dy),i);
x = ((wal->x-globalposx)<<8); y = ((wal->y-globalposy)<<8);
globalx1 = dmulscale16(-x,dx,-y,dy);
globaly1 = mulscale12(dmulscale16(-y,dx,x,dy),i);
x = globalx2; y = globaly2;
globalx2 = dmulscale16(x,dx,y,dy);
globaly2 = mulscale12(dmulscale16(-y,dx,x,dy),i);
if (globalorientation&0x4)
i = globalx; globalx = -globaly; globaly = -i;
i = globalx1; globalx1 = globaly1; globaly1 = i;
i = globalx2; globalx2 = -globaly2; globaly2 = -i;
if (globalorientation&0x10) { globalx1 = -globalx1, globalx2 = -globalx2, globalx = -globalx; }
if (globalorientation&0x20) { globaly1 = -globaly1, globaly2 = -globaly2, globaly = -globaly; }
//isn't "daz" a texture scale for the whole function here?
daz = dmulscale9(wx,globalposy-wal->y,-wy,globalposx-wal->x) + ((daz-globalposz)<<8);
globalx2 = mulscale20(globalx2,daz); globalx = mulscale28(globalx,daz);
globaly2 = mulscale20(globaly2,-daz); globaly = mulscale28(globaly,-daz);
i = 8-(picsiz[globalpicnum]&15); j = 8-(picsiz[globalpicnum]>>4);
if (globalorientation&8) { i++; j++; }
globalx1 <<= (i+12); globalx2 <<= i; globalx <<= i;
globaly1 <<= (j+12); globaly2 <<= j; globaly <<= j;
if (dastat == 0)
globalx1 += (((long)sec->ceilingxpanning)<<24);
globaly1 += (((long)sec->ceilingypanning)<<24);
else
globalx1 += (((long)sec->floorxpanning)<<24);
globaly1 += (((long)sec->floorypanning)<<24);
asm1 = -(globalzd>>(16-BITSOFPRECISNLQ));
globvis = globalvisibility;
if (sec->visibility != 0) globvis = mulscale4(globvis,(long)((unsigned char)(sec->visibility+16)));
globvis = mulscale13(globvis,daz);
globvis = mulscale16(globvis,xdimscale);
j = FP_OFF(palookup[globalpal]);
setupslopevlin2(((long)(picsiz[globalpicnum]&15))+(((long)(picsiz[globalpicnum]>>4))<<8),waloff[globalpicnum],-ylookup[1]);
l = (globalzd>>16);
shinc = mulscale16(globalz,xdimenscale);
if (shinc > 0) shoffs = (4<<15); else shoffs = ((2044-ydimen)<<15);
if (dastat == 0) y1 = umost[dax1]; else y1 = max(umost[dax1],dplc[dax1]);
m1 = mulscale16(y1,globalzd) + (globalzx>>6);
//Avoid visibility overflow by crossing horizon
if (globalzd > 0) m1 += (globalzd>>16); else m1 -= (globalzd>>16);
m2 = m1+l;
mptr1 = (long *)&slopalookup[y1+(shoffs>>15)]; mptr2 = mptr1+1;
for(x=dax1;x<=dax2;x++)
if (dastat == 0) { y1 = umost[x]; y2 = min(dmost[x],uplc[x])-1; }
else { y1 = max(umost[x],dplc[x]); y2 = dmost[x]-1; }
if (y1 <= y2)
nptr1 = (long *)&slopalookup[y1+(shoffs>>15)];
nptr2 = (long *)&slopalookup[y2+(shoffs>>15)];
while (nptr1 <= mptr1)
*mptr1-- = j + (getpalookup((long)mulscale24(krecipasm(m1),globvis),globalshade)<<8);
m1 -= l;
while (nptr2 >= mptr2)
*mptr2++ = j + (getpalookup((long)mulscale24(krecipasm(m2),globvis),globalshade)<<8);
m2 += l;
if ( (dastat) == 0)
//ceilings
globalx3 = (globalx2>>10);
globaly3 = (globaly2>>10);
} else {
//floors
globalx3 = -(globalx2>>10);
globaly3 = -(globaly2>>10);
// Replace globalx3/globaly3 with scaled versions
surfx = globalx3 / SCALEFACTOR;
surfy = globaly3 / SCALEFACTOR;
surfz = globalz / SCALEFACTOR;
// Calculate stepping parameters
surfstepx = globalx / SCALEFACTOR;
surfstepy = globaly / SCALEFACTOR;
surfstepz = globalz / SCALEFACTOR;
asm3 = mulscale16(y2,globalzd) + (globalzx>>6);
slopevlin2(ylookup[y2]+x+frameoffset,krecipasm(asm3>>3),(long)nptr2,y2-y1+1,globalx1,globaly1);
if ((x&15) == 0) faketimerhandler();
globalx2 += globalx + (globalx >> 16);
globaly2 += globaly + (globaly >> 16);
globalzx += globalz;
surfx += surfstepx;
surfy += surfstepy;
surfz += surfstepz;
shoffs += shinc;
Reply 43 of 51, by Darkcrafter07
marxveix wrote on 2025-10-24, 18:07:
Thank you! I try it later, but not today.
You're welcome but don't hurry, this version is really buggy and may make your computer freeze, there are illegal memory writes are still going.
Upd... fixed
Reply 44 of 51, by marxveix
Darkcrafter07 wrote on 2025-10-24, 18:12:
Upd... fixed
Now its bugfixed, better to try with it?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 45 of 51, by Darkcrafter07
Yes but it still looks wonky, I don't know for a way to fix it yet.
Reply 46 of 51, by Darkcrafter07
v0.17 - distance rendering optimization. Make distant walls render less 8 times less often than close according to the game ticker. May speed-up rendering on big open maps but may introduce visual artifacts. Enable by typing /distslow command line parameter. Both Duke07.exe and D07LQ2x.exe are bundled with this. Currently acts since 32000 map units. Edit engine.c or eng386.c drawalls_distslow function to change distance.
Duke07_src_n_exe_v017
Reply 47 of 51, by marxveix
Darkcrafter07 wrote on 2025-12-29, 06:49:
Thanks, downloaded it for later use.
Reply 48 of 51, by Darkcrafter07
marxveix wrote on 2025-12-29, 07:06:
You're welocme, glad someone found it cool! Btw, there must be a better way to do that distance magic but that must be hard to implement.
So we're rendering sky first (the background), as we know that parallax skies setup is done not so flexible in the game so for a parallax map to show up all tiles it consists of, the entire enclosed area must have the same picnum.
So for the idea to work there must be an option to override all skies in the area or even the whole map.
That could also lead to bad picture in the distance as distant geometry can't keep up, so maybe additional parallax-sky-alike horizontal and vertical scrolling on the distance geometry buffer, so the roadmap will be like:
1) Render distant geometry in a separate buffer and apply parallax scrolling to it;
2) Use a 2nd buffer and render parallax skies first here;
3) Copy distant geometry buffer result (scrolling corrected) and draw on top of sky;
4) On the top of it all render only close geometry.
Reply 49 of 51, by Darkcrafter07
So I could finally get a bit further regarding the non-fpu slopes. It still does use some FPU operations like krecipasm calls but tries to do it less.
Texture bending and drifting effect reduced due to onscreen slope segmenting aka tesselation. The fpu krecipasm routine (reciprocal of 1/z) is attempted to be skipped each scanline (SLOPE_FPU_FACTOR = 1).
Here's exe and src of the quite unstable version but working... The result looks sawwy and jaggy but pixelization is less (3x instead of 8x). I heard there are techniques like subpixel correction but it's a wonder it works at least like this.
Use "/nofpu" argument to activate.
Reply 50 of 51, by Darkcrafter07
Hmm we're getting some progress on integer slopes again:
- slopes off the screen solved (faulty int add command in a.asm slopevlin2 in bigslopeloop);
- fully integer versions of krecipasm each with their own reciptables (separate for texturing and shading), that gives solid FPS boost (up to 50% ?);
- a lookup table optimized segments texture calculation (+15% FPS);
As usual, use "/nofpu" command to activate...
Reply 51 of 51, by Darkcrafter07
Some work is going on the alternative implementation based on Ken's own C variant of setupslopevlin-slopevlin function but optimized.
Use "/nofpu" command as always.
