Roland SC-55 connection
First post, by Retronerd878
Hello!
I intend to buy the Roland SC55 (ST) and connect it to my windows 95 socket 7 machine for that sweet MIDI goodness. Right now I have an AWE64 Gold sound card. Will it be as simple as hooking up the Roland interface via the joystick port?
Anything I should be aware of?
Reply 1 of 11, by keropi
Retronerd878 wrote on 2026-01-22, 15:07:
Hello!
yep, it's that simple: you need a gameport midi cable/adapter , you connect the MIDI OUT from cable to MIDI IN of SC-55 and that's it
Reply 2 of 11, by Retronerd878
I've read things abut bugs and stuff. Will it work fine with the AWE64 Gold? Or maybe should I look for another sound card?
Reply 3 of 11, by TheMLGladiator
AWE64 is hanging note free.
Reply 4 of 11, by SuperDeadite
Retronerd878 wrote on 2026-01-23, 05:53:
Just be sure you get a quality Gameport MIDI cable. Most of the cheap generic ones are garbage. If you don't need joystick ports and MIDI at the same time, I'd recommend the adapter from Serdaco.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 5 of 11, by NeoG_
The only issue the AWE64 Gold has related to MIDI is the slowdown bug, where MIDI playback can slow down if simultanouely using high quality digtital audio (e.g. in BUILD engine games). If you are not going to run into that scenario it will be pretty much perfect.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 6 of 11, by Retronerd878
I finally received the Roland SC-55 MKII, but I can’t get it to work. I have the Serdaco MIDI adapter connected to the gameport of my AWE64 Gold, and a MIDI-to-MIDI cable from the adapter going into the MIDI IN port of the Roland. I also connected the RCA outputs of the Roland directly to my speakers (the speakers support two simultaneous inputs), but I still get no sound.
I installed Duke Nukem 3D and in the sound setup I selected General MIDI at port 330, but there is still no sound and nothing shows any activity on the Roland display.
If I play the built-in demo sounds on the Roland, everything works fine, so the unit itself seems OK.
Are there any settings I need to configure on the Roland interface?
Reply 7 of 11, by Retronerd878
Actually now I selected general midi and it plays the MIDI wavetable of the AWE64. What am I doing wrong?
Reply 8 of 11, by sfryers
Make sure the switch on the rear of the SC-55 is set to 'MIDI'. If you're running Duke Nukem from Windows 95, I recall there's a setting somewhere in the AWE Control Panel to select internal/external MIDI.
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 9 of 11, by NeoG_
"Just plug it in and it works" is overselling the simplicity just a bit. For windows applications you need to go into multimedia settings and select "External MIDI" as the MIDI device. For DOS applications, you need to use the AWE configuration utility to disable MPU-401 emulation (which is the setting that directs MIDI data to the onboard wavetable). And make sure the games are configured for the same MIDI port that the card is set to use.
Reply 10 of 11, by Retronerd878
Finally got it to work. Indeed you need to go to Control panel -> Multimedia -> MIDI -> External MIDI device checked. Also you need to go to AWE64 control and select devices and then disable the MPU401.
Just as a side note, normally you would wire the RCA outputs of the Roland interface to the Line-in of the sound card. However, when wiring the Roland directly to the speakers (my speakers accepts 2 inputs simultaneously), the sound quality is greatly improved
Reply 11 of 11, by Spikey
Sure, because you've avoided a round of noise and unnecessary conversions. The headphone jack would be the same.
