First post, by Kasreyn
Hi all,
I'm trying to bring an old 486 back to life that's been sitting in our basement, please help!
It just doesn't want to output anything over VGA, I've tried with either PCI or VLB ISA, "S3 Trio64" and "Trident TGUI9400CXi PM-V551 REV A"
The Trio64 tested OK in a MSI AGP system but the Trident I'm unsure about, do I need to touch the jumpers?
https://stason.org/TULARC/pc/graphics-cards/U … -VERSION-1.html
After some reading on vogons, it seems 486-VIP-IO2 is picky on PCI VGA.
I've done some steps towards troubleshooting, this is what I tried so far:
Voltage for socket 3, without jumpers in the regulator board it's 3.47V and jumpered for Cyrix it's 4.0V.
To get the readouts I followed https://www.dosdays.co.uk/topics/review_fic_4 … vip-io2_pt1.php
So it should give correct voltage for a DX4-100, it gets hot, but does that mean it's a good working CPU? A known good SX 33 MHz did not help.
Voltages for ISA, the upper ISA slot has +5V -5V -12V but I didn't measure the remaining pins.
Flashing a new BIOS:
The label on the BIOS IC says "486DX AWARD SOFTWARE INC. 5.12W2P 2857966"
Comparing the hex (dumped using XGecu Pro) the original BIOS has the same structure as 486-VIP-IO's "427gn2a.zip" BIOS.
The later "1175g701.zip" BIOS specifically for 486-VIO-IO2 do not have the same blank block in the beginning (0000-BFF0).
"427gn2a.zip" BIOS should work on either of these boards?
I dumped the original BIOS before flashing: http://opa.crabdance.com/bin/486DX-AWARD-2857966-5.12W2P.BIN
Other BIOS I've tried:
http://cwcyrix.duckdns.org/ftp-archives/ftp.f … -io/427gn2a.zip
http://cwcyrix.duckdns.org/ftp-archives/ftp.f … o2/1175g701.zip
Other things I tried:
  • Removing the cache ICs
  • Using a different PSU
  • Changing the RAM (it has FPM RAM "NEC 424400") from just one stick to switching from BANK0 to BANK1 to all banks populated.
  • Moving the jumpers around,
    JV1 + JV2: 0/1 wait states &| "<= 33MHz" &| "= 33MHz"
    J28 + JT1: "PCICLK = CPUCLK" | "PCICLK = CPUCLK/2"
    J29: Monitor type select CGA/VGA
    JC4: P24T/P24D cache type select write back closed/open
None of these things have really helped getting it to output anything over VGA.
Pictures of the board and GPU:
http://opa.crabdance.com/img/486-VIP-IO2-1.jpg
http://opa.crabdance.com/img/486-VIP-IO2-2.jpg
Jumper settings from manuals:
https://stason.org/TULARC/pc/motherboards/F/F … 86-VIP-IO2.html
download/file.php?id=21444
FPM RAM "NEC 424400":
https://classiccomputershop.eu/Webwinkel-Prod … -retro-90s.html
Reply 1 of 11, by majestyk
BIOSes 427gn2a and 3276gn1 are not for VIP-IO2, just for VIP-IO and some other models.
You should stick to one of these:
http://cwcyrix.duckdns.org/ftp-archives/ftp.f … 86/486-vip-io2/
Im´m running my own VIP-IO2 with one of them (not sure which one).
I don´t think this board is especially picky about video cards but the jumpering must be 100% correct - otherwise it won´t boot. This also goes for the CPU core voltage.
Did you try a ISA graphics card?
Did you try a 5V CPU with the VRM module removed and 4 jumpers set instead?
Reply 2 of 11, by Socket3
the board is also picky about ram, and will not beep with no ram installed (witch is very weird). Most of the time if your FIC VIP-IO/IO2/GIO/VP2 will not post, it's because of ram it does not like, not because of the video card.
My advice for getting the board running is:
- use a better supported CPU (Intel or AMD DX2 for example) for testing
- get a hold of some more FPM ram and make sure it's fast page, as it can be hard to tell if SIMMS are FPM or EDO just by looking at them - something with Ti or SEC chips will run on these boards for sure
- get a hold of an ISA video card. Any card, just for diagnostic purposes
- since you flashed the bios, make sure you change the jumper to the right of the bios socket from 1-2 to 2-3 (1-2 -> EPROM, 2-3 -> Flash EEPROM).
Reply 3 of 11, by Kasreyn
Thanks for replies!
majestyk wrote on 2021-06-19, 05:18:
I only have the VLB ISA card at the moment, I'll order one 😀
I think the Trident can't be configured to run off the ISA bus so maybe it's VLB only.
Yes, I tried it today and measured the socket voltage again, it's not spot on 5.0V but around 4.9xV.
Socket3 wrote on 2021-06-19, 07:27:
Aha! I just ordered two of these, A80486DX2-80NV8T & A80486DX2-66NV8T.
Also I flashed "1164g701.zip" and nothing. Same with CMOS clear, does that need to be done while the system is offline? am I supposed to remove the battery?
I found a pin compatible RAM module from the other 486 and tried that, nothing.
"KOREA B007 9451 FFF HM514400BS7" printed on the ICs so it's FPM https://ram-co-shop.de/4-MB-FPM-RAM-non-Parit … i-HM514400BS7_1
The BIOS I tried:
http://cwcyrix.duckdns.org/ftp-archives/ftp.f … o2/1164g701.zip
Reply 4 of 11, by Socket3
VLB and ISA are completly different busses... a VLB card will not run off the ISA bus alone...
Reply 5 of 11, by Socket3
Kasreyn wrote on 2021-06-19, 11:18:
Also I flashed "1164g701.zip" and nothing. Same with CMOS clear, does that need to be done while the system is offline? am I sup […]
The BIOS I tried:
In that case you probably missed a jumper. The VIP-IO and IO2 also have 4 resistor networks (long balack things with pins - RN20 and RN22 if I remember correctly, they're between the voltage regulator module and the CPU socket) that need to be correctly configured for the board to post, make sure you set them up correctly as wel
Reply 6 of 11, by Kasreyn
I have now re-tested this with an AMD DX2 66MHz + ISA GPU, but the issue persists, no VGA output.
POST codes are either "09 08" or "C5 C1".
It can end up at either after power cycle but usually it ends up at the former.
I removed the cache ICs + tag, sprayed some contact cleaner + toothbrush, after that the POST codes are usually "08 C5", strange!
Any ideas what else I can try to get this stubborn motherboard working?
Picture below of how I have configured the jumpers, it should be correct for AMD DX2 but there might be something I missed.
http://opa.crabdance.com/txt/486-VIP-IO2%20Mo … nfiguration.pdf
Reply 7 of 11, by CoffeeOne
J7 and J29 should be both open. J7 closed is cmos memory clear, if you set this the board will not power up.
Reply 8 of 11, by evasive
Page has been updated:
https://theretroweb.com/motherboards/s/fic-486-vip-io2
The bios that was sent by email is not for this board BTW. It's for a VT82C495 series chipset, not this one. On the page 2 bioses are listed that should work with this board. There's also a complete user manual.
Reply 9 of 11, by Kasreyn
Thanks for the info @evasive
Sounds like this could be why it isn't working or a way to get it working again !
It spent the last decade untouched in my basement, as far as I know it's the original BIOS that I dumped, it's why I linked to it in my initial post.
I didn't have access to a programmer until recently and this was the only 486 with this type of BIOS, so it couldn't have been swapped in from a different computer.
But as you may know, memory can be a little fuzzy recalling the history of a specific computer after so many years 😀 I seem to recall it was working and one of the HDDs from it boots into Linux 2.2 I might have used it as an IRC client..
Anyway.. thanks for this.. I will be trying the BIOS from https://theretroweb.com/motherboards/s/fic-48 … p-io2#downloads
Reply 10 of 11, by mt777
Do you have also extremaly hot Winbond chip ? This big square next to keyboard.
Reply 11 of 11, by baquerosergio@hotmai
Some update?, have the same board and the same problem. NO post, no beep.
Could you post this board, already?
