First post, by Lualb
Hi guys
I'm trying to connect a Windows Millennium PC to the network, and when I try to install the driver, Windows detects it, but after restarting, I get an error in Device Manager. The important thing is that the system recognizes it. I'm attaching some screenshots of the installation process and the final result.
The Ethernet controller is Realtel RTL8111H, and according to several downloads, the driver is compatible with Win98/ME..
Reply 1 of 7, by nali
Did you try moving it in a different PCI slot ?
Problems often happen with Win98 and network cards if they share Irq with other devices.
Reply 2 of 7, by Lualb
nali wrote on 2026-03-10, 17:40:
Hi!
Unfortunately, it's a chip integrated into the motherboard, and the board only has one PCI-E slot, but I'll check the IRQ.
Reply 3 of 7, by nali
If the chip is integrated, I suppose it's a "modern" mainboard.
Maybe with also sound.
I would disable every integrated device in the bios, excepted the network card of course, to see if it makes a difference.
Reply 4 of 7, by Lualb
nali wrote on 2026-03-10, 18:01:
That's right, it's a modern motherboard with the Intel H81m chipset.
Also, I'll check the BIOS devices now to disable them.
Reply 5 of 7, by Lualb
There's definitely no conflict with other devices; it's the only device with IRQ 3. I think I'll have to look for a PCIe card with an older Realtek driver, because the one integrated into my motherboard is somewhat incompatible, even though Windows recognizes it.
Or maybe I'll install Windows 2000 and try installing it there jejeje.
Reply 6 of 7, by nali
Even if some drivers pretend to work, very often they don't in fact.
Maybe you could try to boot a Linux from Usb, just to make sure the card has no problem and really work.
For Win98, I have a basic Realteck 8139, and I had to try many drivers before I find one that really works.
Reply 7 of 7, by Lualb
Hi everyone! I wanted to let you know that I’m still trying to install and get the integrated Ethernet controller on my motherboard—the Realtek RTL 8111H—up and running. I think I’ll need some A.I help, because I’ve tried everything I can think of but haven't been able to get it working on Win98SE/ME—at least not for now
