Reply 30940 of 30955, by tehsiggi
Some more R300 series fun in the lunch break.
So I build the jankiest temperature controlled setup possible to characterize the NTC on R300/R350/R360 GPUs. It consists of a styrofoam box, a 40mm fan, a 20W light bulb, Uni-T thermometer and a cheap module to control the lamps heating.
The attachment box_setup.jpeg is no longer available
The attachment tool_setup.jpeg is no longer available
I used a voltage divider consisting of the GPUs NTC and a 100kOhm 0.1% low-temp-co resistor, powered by a lipo cell (gives nice, clean and stable voltage) to determine the resistance of the NTC.
The attachment prepped_r350.jpeg is no longer available
The attachment divider_lipo.jpeg is no longer available
The results look like this:
The attachment output.png is no longer available
I know, it's no-where scientific, but for me it's honestly good enough.
So calculated my results look like this:
Beta Model Parameters
Beta (B): 4329.96 K
R25: 94652.81 Ω
Steinhart–Hart Coefficients
A = 0.0008714636826900755
B = 0.00020751383834629025
C = 0.00000006987140028267289
It's relatively safe to assume it's a beta 4250K part, which is pretty common.
This will now help me to read the temperature on R300 based cards, pretty close to the die. Unfortunately, no diode in the die. But hey, better than nothing.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30941 of 30955, by ChrisK
Haha, love those setups.
Looks absolutely scientific 😁
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 30942 of 30955, by tehsiggi
Well, it at least got close enough and produced usable values 😁
And I only bought the thermostat module, as I needed that one anyways. The rest was laying around. Guess I'll make it a science fair project?
EDIT:
ChrisK wrote on Yesterday, 13:14:
Okay, I couldn't resist. MORE JANK! For science of course.
STM32 Bluepill, some I2C display + a quick code with the Steinhart-Hart values. I am impressed. The top temperature on the UniT is the thermal probe on the R350, the LCD shows the calculated temperature from the GPUs NTC.
Reply 30943 of 30955, by PcBytes
@tehsiggi hope this photo helps, came from the guy I got the reference DELL 9800XT from. Currently can't unscrew the cooler as I need to source some 1mm or 0.8 Arctic pads. I do notice a transistor close to the core? Is that the specific part you're looking for?
Reply 30944 of 30955, by tehsiggi
PcBytes wrote on Yesterday, 15:37:
Yep, that picture is already good enough. Clearly using the transistor as the sensor for the core temperature. Thank you very much!
Reply 30945 of 30955, by TechieDude
TechieDude wrote on Yesterday, 01:38:
Well, after my P3 Voodoo3 build started to throw RAM errors AGAIN, even after already replacing the DIMMs, it was probably time […]
Well, after my P3 Voodoo3 build started to throw RAM errors AGAIN, even after already replacing the DIMMs, it was probably time to retire it. That QDI Advance 10T served me well for a full decade, but failing DIMMs so soon after the previous RAM failure is VERY suspicious... I only had these in that board for 2 weeks...
But what could replace it anyway? The reason I had that system was to have the best possible compatibility with 90's games, while also having good performance. Not exactly period-correct, since I never really go for that, although its original specs were very much period-correct, with a Soyo SY-6VBA133, P2 400, SBLive! and Voodoo3, it quickly evolved to a PGA370 P3 (mostly because the original board died, and I ended up upgrading to the QDI), only keeping the Voodoo and SBLive! constantly. It even was a P4 build briefly, before settling on that QDI board (I really dislike Netburst, and for some reason that particular config caused problems with some games anyway.) That QDI in of itself went from P3 650MHz to Tualeron 1.2GHz, to P3-S 1266MHz OCed @ 1.3GHz. Surprisingly, the same Win98SE install took all those changes (even the motherboards) like a champ over the years without a hitch. I wouldn't really mind reinstalling the OS, it just didn't happen to be necessary.
So, what is the next step? Well, I have an MSI K7T266 Pro2 V2.0 (with the extra Promise FastTrak100 and NEC USB2 builtin), a few socket 462 CPUs, plenty of DDR DIMMs (although just one 512MB was more than enough while also being perfectly stable without patches), and more than enough time to rebuild everything. I settled on an Athlon XP 1800+ Palomino (~1.56GHz), 512MB DDR400 (allows for very tight timings on 266 speeds), and basically kept everything else the same. Build went nice, almost too nice...
Just for shits and giggles, I hooked up that same Win98SE HDD to see if that will work. And well... IT ACTUALLY DID! 🤯 No BSOD, no conflicts, no falling back to DOS Compatibility Mode, just automatically reinstalling the proper drivers for the new configuration, and after that, happily playing the startup sound, and loading my desktop. One reboot just for good measure, and everything is still fine. Now,I'm no stranger to getting Windows XP and later installs working on different motherboards even when SATA controllers were different (injecting drivers on existing installations is especially easy on Vista and later, and yes, I also did it just for fun), but that was from G41 chipset to Z77, and it still needed some finagling with drivers and reboots, even though when I was done, it was just fine. This? I expected it to be considerably worse, since everyone here knows how temperamental Win9x can be, but it was even smoother instead. It probably helped that they were similar enough VIA chipsets, and used the same drivers.
I also have another HDD on that PC with WinXP, mostly to see if I can get working Glide support in that, but the drivers have failed me there again and again. (Any recommendations for XP Voodoo3 drivers??). I also tried that, but ironically, that failed spectacularly with an UNMOUNTABLE_BOOT_VOLUME. Not good, and that's not due to the motherboard being different, it might be an actual HDD problem.
Dumbass me celebrated too damn early, I also got to experience the joy of a Sound Blaster Live! shitting the bed with a VIA chipset... For some reason, I had never encountered that bug, because it apparently only happens when the card shares IRQs with other devices, and through all my PCs, it somehow always had its own IRQ, but not here. No matter the slot, it just HAS to share with some stupid device now... Guess I might upgrade to an Audigy 2 ZS, though I REALLY like the Live Drive IR too much to get rid of it.
Reply 30946 of 30955, by PcBytes
tehsiggi wrote on Yesterday, 15:39:
You're welcome! For what I paid on thjis card (way too much for a R360, I know, but it's working and it passed the endurance tests I've gave it) it's nice to see it helps us both. Paid circa 93 euro on it, and it came with 24mW/K pads (holy overkill Batman!) from a brand called Upsiren + MX4 repaste on core, as well as the whole card cleaned up.
Reply 30947 of 30955, by tehsiggi
PcBytes wrote on Yesterday, 23:27:
Well, good news is the card is using the reference 9800XT PCB, so you basically got a working 9800XT for 100€ - which I think is pretty decent. I'll think I'll never own one. The hunt is just to much for me to bear and most of my interest is more scientific than any real-world usage. Seeing how they are traded, it feels you'd not really want to use it in daily retro machines. Which I think is a pity, same as for the 9700Pros - which got so rare, people rather put them on shelves and collect them rather than using them.
I'll take a look today at the unloved child of the R300 Series, the 9500 Pro. Got one here that had a rough time, so I'll see if I can fix it up.
PS: The one cap near the slot bracket got a funky repair 😉
Reply 30948 of 30955, by PcBytes
tehsiggi wrote on Today, 05:35:
Well, good news is the card is using the reference 9800XT PCB, so you basically got a working 9800XT for 100€ - which I think is […]
Ah yeah, that cap 🤣 - it got fixed before being shipped to me most likely.
The reason it uses the reference OCB is well... it IS a reference card after all, just tagged for Dell w/ specific barcode stickers on the back. Same goes for the X800SE PCI-E I mentioned below and I also found my working R350 that way.
brw finding a normal bracket proves to be a challenge - so far none of the brackets I tested seem to work, including one off a reference X800SE PCIE 🤣
Reply 30949 of 30955, by tehsiggi
That cap is pretty small for what should be there. According to pictures it would be the same 1200µF 4V as the other ones. The one installed right now looks like 100µF? 😁
Reply 30950 of 30955, by Shponglefan
Had a pair of Roland SC-55ST sound modules on the bench today.
The attachment Roland SC-55ST.jpg is no longer available
I opened them up to see if there was anything worth servicing inside. Other than cleaning the volume pot and rear switch, there wasn't much to these. No glue to remove, no batteries to replace.
The attachment Roland SC-55ST boards.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 30951 of 30955, by wierd_w
Check the solder joins on the rc and midi ports?
Check the voltage regulator for heating?
None of the caps look blown.
Looks like a very clean design in there. Very little that might fail.
Reply 30952 of 30955, by Shponglefan
I didn't remove the boards to check solder joints directly. I did test them by hooking them up and wiggling the various connections (power, MIDI, audio). Nothing got interrupted so I'm assuming the solder joints are all good.
Didn't think to test the voltage regulators for heat. They've got decent heatsinks on them though, so again, I'm assuming they're probably fine.
Other than an IC going bad, there isn't much else that could go wrong with these.
Reply 30953 of 30955, by Nexxen
I have an Alienware Aurora R4.
The water cooler isn't working anymore, probably not enough water left.
Tryina figuring out how to put coolant inside, apart from opening the base/pump I don't see any hole for a refill.
One pipe is hot, the other one is cool. Temps go up to 100°C.
I'll probably start a thread.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 30954 of 30955, by tehsiggi
Unloved child was an understatement. Somebody really hated this card. I'll add it to the repair collection tomorrow or friday, still some things to sort out. But I got it from complete artifacting with no real picture to working nicely in 2D and 3D like nothing ever happened.
The attachment bodge.jpeg is no longer available
The attachment nature.jpeg is no longer available
Over a dozen resistors and caps where missing. The complete compensation network of one regulator was gone, bulk caps. Ohh and to not forget: CKE for memory channel D is dead (used a bodged pull-up to fix it for now) and bits 5 and 6 of the C channel where gone.. the reason was easily found upon inspection.
The attachment PHO00040.JPG is no longer available
The attachment PHO00042.JPG is no longer available
Reply 30955 of 30955, by Twisted Six
Today's positive object lesson was recapping a Tyan S2895 dual opteron board from ~2006-ish. I have a client that sends me a couple of these a year; they have a small fleet of them still in operation. Best I could gather some kind of medical imaging devices. They told me the re-licensing would cost a fortune if they replaced them.
Anyway, you have not earned your recapping man card until you've done atleast 3 of them.....they take for farking ever; tons of capacitors to replace!!
file.php?mode=view&id=238111
This thing is a power sucking pig....and all it's running is memtest...
file.php?mode=view&id=238112
file.php?mode=view&id=238113
There's 16gb RAM in it....the glare made that impossible to see.
file.php?mode=view&id=238114
If you tolerate this, then your children will be next.
