NeoG_ wrote on Yesterday, 21:54:I can confirm on my computer with latest official PicoGUS firmware I can: […]
theelf wrote on Yesterday, 16:02:
Hi! i have official latest firmware, and every time i change USB did not work until power off/on, if i change usb while PC on, cdlist always give the list of files that was on usb pendrive when power on. Even a reset did not work
- Turn on the computer with or without a USB drive inserted
- Insert a USB drive and get an updated cd list while the computer is on
- Mount and use any new images put on the USB drive when inserted without powering off or resetting
If your cd list is freezing, there is likely an issue with one of the cd images, or the name of one of the cd images in the list. Maybe you can export the cdlist to a text file and show Delphius to see if there is a firmware bug related to it. It could be issues with non-english character sets for example.
Hi, thanks reply, here Picogus v3.2.1 firmware
Impossible must be name problem, because i use 001.iso, 002.iso, 003.cue/iso, etc i dont like to use names
This is what happen to me
[*]Turn on the computer with or without a USB drive inserted
[*]Insert a USB drive and get an updated cd list while the computer is on
[*]Mount and use any new images put on the USB drive when inserted without powering off or resetting
[*]Unplug USB
[*]Insert new USB
[*]cdlist show same list of FIRST usb until power off/on
Same happen if i use the picogus in my 286 or 486 PC
But i will reflash picogus and test again, knowing need to work. I just believe was normal behavior thats why never care much of this
