First post, by CkRtech
- Oldbie
I have been messing with several VLB cards of late, and I cannot seem to get a solid 320x200 VESA mode solution at 256 colors for the S3 805 chip
Various Univbe executions result in the following:
Univbe 5.1a is the only one that produces an image for 320x200x8. That said, the image is glitchy. Duke Nukem has this same odd effect. Fastdoom uses the mode and looks fine.
Univbe 5.3a produces a signal that is out of range - 140+ Hz.
Univbe 6.5 does not offer a 320x200x8 mode after execution, and also provides a warning for 320x200 with LFB - "Note that due to a hardware problem, S3 86c805 chips do no support linear framebuffer access in 320x 8-bit SVGA modes."
Very interesting. I wonder what the specific reason for this is. If you know, please share. I may have managed a banked 320x200x8 mode once just from messing with Uvconfig parameters, however I do not think it was functional.
Any thoughts on obtaining a legitimate 320x200x256 color with a proper refresh rate on an S3 805 chip?
