I hope to finish the new design today (assigning JLCPCB parts for the order, rechecking all connections, and finalizing the routing). The past two weeks have been quite busy, so I didn’t have much time to work on hobby projects.
I might pick up a Keystone bracket today to do a fit test with a paper prototype.
The new card is basically the same design, just polished a bit and optimized for manufacturing at JLCPCB. Some component part numbers were changed to better match parts available there.
I also added a dedicated oscillator instead of relying on the ISA bus clock, since a user reported that the sound could be slightly off on some systems.
The voltage divider on the PC speaker mix-in will be adjusted to allow higher loudness.
I'm also switching to a Keystone metal bracket. The old design was originally converted from Eagle CAD, which caused quite a few consistency issues when replacing parts, so starting from a clean layout seemed more reasonable.
I also noticed that JLCPCB now offers metal cutting and bending services. In the future it might even be possible to order the bracket directly from them.
