Reply 160 of 185, by bertrammatrix
feipoa wrote on 2025-11-04, 12:54:The issue with Cyrix 5x86-120 chips and the 1024K module have been resolved. It seems that IBM 5x86c-100 chips soldered onto Th […]
The issue with Cyrix 5x86-120 chips and the 1024K module have been resolved. It seems that IBM 5x86c-100 chips soldered onto Thinkpad interposers are not well liked by the M919. Switching to some other interposers resolved the issues at 120 MHz with 1024K cache. This is odd because every other socket 3 motherboard I tested worked well with the Thinkpad interposers.
I was able to achieve a stable M919 with 1024K and Cx5x86-120 MHz with 2-1-2 and 0/0 ws. I used 8 ns SRAM (TSOP) and 50 ns EDO (TSOP).
Note that if you need to use 1/0 ws with EDO, you can get slightly better performance if you have some FPM that runs with 1/0 ws. For example, on the M919, and (I think) MB-8433UUD when running an Am5x86-180, Cachechk v7 as follows:
EDO 0/0 ws --- memory read speed = 66.8 mb/sFPM 1/0 ws --- memory read speed = 55.4 mb/sEDO 1/0 ws --- memory read speed = 52.6 mb/sAnd when running a Cx5x86-120, Cachechk v7 as follows:
EDO 0/0 ws --- memory read speed = 55.2 mb/sFPM 0/0 ws --- memory read speed = 55.2 mb/sFPM 1/0 ws --- memory read speed = 43.9 mb/sEDO 1/0 ws --- memory read speed = 41.3 mb/s
Very, very impressive, I didn't think anyone would get one to run at 2-1-2 at 60mhz. Once again, you did it 😎
Was this with one of the latest s1R3 qfp CPUs or one of the older ones you had, or does the revision seem to affect the capability to run the tight timings at all? Did you also try with a regular IBM pga chip?
The 8ns sram must be giving you an extra edge here, especially in the tag
Is it windows stable is the next question 😀
