RetroGear1 wrote on 2026-03-17, 01:26:
It gives the message to insert disk so no activity.
The message doesn't mean "no activity" - it means it couldn't read from the disk.
Does the drive LED come on when you try to access it? Does it spin.
Is it enabled in BIOS and set to the right drive type?
There are two distinctly different 3,5: drive types which look the same, but operate at different data rates and won't work if not set to the right type.
(Since you tried a bunch of drives, I'm guessing that at least one was a 1.44M HD)
When you restart, does the drive LED come on and does it perform a seek as BIOS tests it?
If you configure your BIOS to boot from A: before C: does it activate A: then switch to C: after trying for a bit, or does it
boot C: right away. The thing we are trying to figure out is if the system is actually accessing the drive or not.
If really "no activity":
Is the drive jumpered as 2 (second position)?
Are you attaching it at the end of the cable (with the twists inline)?
Do you have any other working floppy drives in the system, or can it boot from USB?
What I'd like to do is boot DOS with ImageDisk on it - ImageDisk will access the drive directly (not through OS or BIOS) and will let us try things like seeking/reading/writing even if it doesn't see the media, so you can do a lot more diagnistics.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
