Reply 560 of 567, by OPLx
BlackVega wrote on 2025-07-04, 17:31:Please see Cosmo Police Galivan: https://vgmrips.net/packs/pack/cosmo-police-g … -police-galivan […]
OPLx wrote on 2025-07-04, 14:34:Could you point me to the VGM data does it not work correctly on? That way I'll have something to validate against when I have a large block of time to look into the issue. Thank you.
https://vgmrips.net/packs/pack/cosmo-police-g … -police-galivanAll tracks sound a little off at times. I suspect other tracks from games from the same developer will do the same. Also some tracks from Duke Nukem 2 hang the system completely
I can use the Cosmo Police to figure improve things. Since there are twenty of them, do you mind telling me which Duke Nukem 2 tracks cause your system to hang? I'll try to look at these as soon as I can. Thank you.
