First post, by cambalinho
i tried several times... but how can i activate the NTFS drivers?
i have some external NTFS drives and i need to see them on Windows 9X
Windows 98 has no built-in NTFS drivers that could be "enabled ".
Search for the "Paragon" NTFS drivers for Windows 98 which are freeware and work flawlessly.
i just did it.. or did something wrong(several installetions) or something.... isn't working 🙁
i put it working before.. but now, maybe i need reinstall the Windows again 🙁
I'm assuming your NTFS drives are over 120GB in size? In this case, in addition to the NTFS file system driver, you will also need a patched one to support large disks, corresponding to ESDI_506.PDR (If you prefer IDE or SATA), or AHCI.PDR (It already contains a fix for large disks), if you prefer AHCI, then the AHCI mode must be set in the BIOS. Actually, for NTFS support, your best bet is to use UFSD.VxD from Paragon Mount Everything. To do this, it is not necessary to use the product itself, just put UFSD.VxD from its composition at the address "C:\WINDOWS\SYSTEM\IOSUBSYS". According to research results, this version is the most versatile, stable, but slightly less productive.
thank you so much for all to all
1541 wrote on 2023-01-08, 20:08:Windows 98 has no built-in NTFS drivers that could be "enabled ".
Does this just read NTFS or write also?
zapbuzz wrote on Today, 05:40:1541 wrote on 2023-01-08, 20:08:Windows 98 has no built-in NTFS drivers that could be "enabled ".
as its manual states, full version can read and write. https://download.paragon-software.com/doc/man … al_ntfs_eng.pdf
roytam1 wrote on Today, 05:53:zapbuzz wrote on Today, 05:40:1541 wrote on 2023-01-08, 20:08:Windows 98 has no built-in NTFS drivers that could be "enabled ".
Interesting, I only ever used this
https://forum.vcfed.org/index.php?threads/doe … o%20be%20stable.
And it was very disappointing
