First post, by Mike_
I have a LiteOn LTR-24103S CD drive in a 486, but the drive occasionally crashes. For example, it froze down when I ejected CD. The computer crashed as well, but after reset it started normally except the drive was not found. Powering it down solved the problem, so I suspect that drive's firmware had crashed.
Currently it has firmware XB03, and it appears that there are newer versions. However, this site I found doesn't have the firmware itself, just a link that doesn't work anymore. Any idea where to find firmwares for old LiteOn drives?
https://www.cdrinfo.com/Sections/Firmware/Sin … spx?DriveId=438
Reply 2 of 5, by Mike_
Thanks, I got it updated. 😀
Reply 5 of 5, by Mike_
zapbuzz wrote on 2026-03-22, 14:04:
did it fix the issue?
It happened only occasionally, so it's too early to say. But it hasn't reoccurred yet.
