First post, by Gabriel-LG
Tonight, I am picking up a watercooled LGA-775 system, that the seller had stored in an attic for 10+ years.
It has an Asus Maximus Formula motherboard with an Nvidia GTX-295 and a 750W Corsair PSU. All housed in a Lian-Li aluminium case.
Both the CPU and the GPU have waterblocks (Innovatek G-Flow and Swiftech Epsilon). But one of the hoses has snapped in half, so potential waterdamage.
My goal is to restore the system (unless the motherboard/GPU are destroyed in the leak).
What can I expect? This system newer than what I usually restore, and also I have never done anything with watercooling.
Any guidance at this point is much appreciated 😉
  • Can I briefly test the system without coolant (just to see if it posts) or is that enough to kill the CPU/GPU?
  • Will waterblocks survive prolonged exposure to water, or will they corrode shut?
  • Can pumps and resevoirs be salvaged?
  • Can (the now very gunky) acryllic be restored?
  • Will the PSU need recapping, and do solid state capacitors survive this long?
  • Can gaskets be replaced?
  • Are hoses and fittings still available?
  • What else should I be asking?
Reply 1 of 11, by bofh.fromhell
Now that's a sweet system, or at least it used to be =)
But I would not put power to it without first doing a complete disassembly and inspection.
Even w/o a cooling loop strange stuff can happen to electronics in 10 years.
Also all parts of the loop should be treated as suspect.
Especially the pump and hoses.
And I would not even try to remove the hoses the "normal" way, I'd just cut them =)
Reply 2 of 11, by Gabriel-LG
The components looked dry on first glance. But then I saw that everything was actually covered in "strawberry juice".
Clearly the fluid contained some type of anti corrosion agent, as the parts appear to have been wet for quite some time already, but no corrosion what so ever.
The fluid was slightly conductive however (my DMM measured 20 to 30 MOhm). So I took everything apart to wash it in demi-water and then rinse with IPA.
It took 3 baths before the water stopped turning pink, then I ran out ouf demi-water...
I also accidentally decapped the Northbridge (the IHS was stuck in the petrified thermalpad). I already had little hopes of saving the motherboard and GPU. This makes it even worse 😐
For some reason the PC had pentium-4 660 isntalled, weird...
The PVC tubes were in very good state. One tube was made of rubber, and this one literally fell apart.
Reply 3 of 11, by momaka
Gabriel-LG wrote on 2026-03-23, 17:11:
Not sure what you mean by this. Do you mean the NB core got cracked / destroyed with the IHS removal? Or something else? (Pictures maybe??)
Might still be salvageable.
The components looked dry on first glance. But then I saw that everything was actually covered in "strawberry juice". Clearly th […]
Yeah, good call on the washing.
I do this now to any motherboard I get. You just never know who did what to the board before getting it and if there may be some dirt or some conductive particle somewhere mucking things up. It's also much easier to inspect the board for broken traces or other damage once it's washed (though I also always give a careful pre-wash inspection too, just in case something is possibly loose and on the verge of getting knocked off and falling into the drain.)
That said, no need to use IPA or deionized water or any of that fancy stuff. Regular warm water + dish detergent is all I use (and have been using for the past 15 years) t0 wash electronics. Just place the motherboard afterwards in a sunny location for it to dry for 2-3 days... *OR* near a fan or air duct if sunlight is not available.
Oof, not exactly a cool-running CPU. Make sense why the system was liquid-cooled. 🤣
Though if you do end up reviving this PC, I would suggest to move it to a different case. While these older Lian-Li cases are pretty nice, the single 80 mm fan on the back cannot really provide much cooling, unless you crank the fan to run at max speed (which would make the PC loud - something I don't think people did too much anymore in that era). Thus, you'd likely end up with a system that runs hotter than it should. The CPU alone will not get enough cooling from that 80 mm fan, even if the water cooling radiator was right there behind it, directly exhausing heat from the system. And with a GTX295... ooof! That's a really hot-running GPU.
I see a power cord on the back of the case, so I imagine the water cooling was a "home-brew" setup of some kind with an aquarium pump?
All in all, I'd say you got a lot of interesting parts from the system. But if it was mine, I would completely gut it and rebuild it in an entirely different way.
The GTX295 could benefit from having it's own water cooling system, separate from the CPU, and with a 120 mm radiator as a minimum (120x240 mm with two 120 mm fan would be much better, given the heat it produces - that is, if you want that card to last a little longer.) Better yet, I'd go back to air-cooling, simply because I personally don't like to deal with the high maintenance (and high risk) of water-cooling systems. But then, that would require finding the stock cooler for this GPU, since this is a dual GPU card and uses a pretty oddball cooling. Thus, you might have to keep the water block (and cooling) with it. But again, I would not use whatever was used with this system. From the pictures you provided, I can't actually see where and how big the radiator is. If it's just that tiny thing on the front 5.25" drive bay, forget it! -That thing won't be enough for the CPU alone. Someone putting both the CPU and GPU on that is asking for serious trouble. It would suffice for a test, though. On that note, if all you want to do is test the GPU (be it in another system or this one), I think the easiest way to do that with reusing whatever parts you have on hand would be to just dump the pump in a large bucket (~ 5 to 6L or ~2 Gal.) full of water and connect that directly to the GPU water block (re-using only the "good" hoses left). No need for a radiator. With a bucket large enough and enough water in it, the bucket itself will suffice as a radiator... at least for some testing (probably 10-20 minutes, maybe... and much less under max GPU load).
In regards to the CPU: it's an obvious mismatch to the rest of the system. A fast C2D with air cooling should be fine... though again, probably not in this particular Lian-Li case. If going with a C2Q, you will definitely want a more open/"breathable" case. Funny enough, that hot P4 Netburst has the same max thermal output as the early Core 2 Quad's. If the board can take Q8x00 or Q9x00 quads, those will be even less power-hungry than the silly P4 while easily providing 4x (or more) the performance.
I can't recall who built the TX series for Corsair and what was in them anymore, but IIRC, they were pretty respectable PSUs and should still be OK to re-use in another system. Best bet to know is to open it and see if there are any bad caps inside... or better yet, post pictures in a new thread for others to double-check what you're seeing in there. That's what these forums are for, so we can share knowledge. 😉
Reply 4 of 11, by Gabriel-LG
The X38 chipset has an IHS. When I removed the chipset cooler, the IHS ended up stuck to cooler. The chip and it's die appear to be OK.
The attachment PXL_20260324_211101391.jpg is no longer available
The thermal pads under under the chipset cooler turned into hard plastic. It does not soften when soaked in IPA, would soaking in naphta help?
The attachment PXL_20260324_211831241.jpg is no longer available
This case has 2 120mm fans holes in the top. So plenty of airflow. For some reason, the radiator is mounted on the wrong side of the fans, so they blow the heated air into the case (unless the fans spin in reverse).
The attachment PXL_20260324_211152903.jpg is no longer available
I suspect the GPU is dead, or it has been repaired. It has a blob of epoxy (or at least it looks and feels like epoxy), I suspect this to be a trace repair job.
The attachment PXL_20260322_204600612.jpg is no longer available
If the motherboard has survived (I will test it in about a week when it has fully dried). Then I plan to put in a Core 2 Q9550, or maybe a QX6850.
Reply 5 of 11, by cyclone3d
Acetone might soften the hard pink goo. The other option is to hear it up since those things are phase change...
Lemon essential oil does work on those, really any strong citrus based product should work.
I wouldn't worry about the North bridge being damaged by the decapping. Just an opportunity to replace the old paste and reglue the cap on with silicone,along sure to have pressure applied evenly so the heat transfer is good.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 11, by rasz_pl
that NB IHS looks like someone already went there and cut the rubber glue to decap it
Reply 7 of 11, by Gabriel-LG
I managed to pop off the IHS by hammering a coxcutter blade in between the cooler and the IHS.
Some acetone and elbow grease removed the remaining thermal pad.
I just tested the motherboard and it survived the whole ordeal 😁
Reply 8 of 11, by PcBytes
The black marks on the GPU aren't epoxy... that component is burnt up and that's soot around it.
Reply 9 of 11, by momaka
PcBytes wrote on 2026-03-30, 20:50:
Good eyes, probably right about that. The component appears to be labeled Q509, which suggests a transistor of some sort... which means that component should look like any other SOT-23 transistor... and it doesn't- so that's a problem! Looks more like a darkened ceramic cap, thus likely fried.
I do wonder what part of the circuit this is for. With some luck, the GPU may still be salvageable.
At least you still got a working mobo and a decent case out of that deal. The water cooling system also looks quite OK, now that you posted those shots showing the top. I still wouldn't use it before doing a full disassembly, inspection, and a full flush to get all of the old cruddy coolant out. Better yet, test the water cooling system without it being attached to any hardware - just power it on from a junky board and see if it leaks after an hour of run time. Sometimes a slow radiator leak won't show until the system has been in use for a good amount of time.
Reply 10 of 11, by NeoG_
Gabriel-LG wrote on 2026-03-24, 21:51:
Since the material has fully hardened and the objects you are trying to separate are metals, my next option would be soaking in acetone
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 11 of 11, by Gabriel-LG
momaka wrote on 2026-04-01, 18:20:
Good eyes, probably right about that. The component appears to be labeled Q509, which suggests a transistor of some sort... whic […]
I just tested the GPU, it works fine! 😁 Although I could not stress it, since the watercooling is not functional yet.
It is a bit hard to tell from the picture, but the black "soot" is actually a solidified drop, and has a solid smooth surface. My guess is that Q509 has been ripped/blown off the board, damaging a trace. This has been repaired with some coil-wire and epoxy.
My guess is that the system was gobbled together by a hobbyist, that is why the components are from several eras. The waterpump has a date code of 2003...
