Reply 60 of 472, by nd22
- l33t
6. 1280*1024 AA 4X with sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
A. KU8
B. KV8 PRO
C. UL8
D. AV8
7. Code creatures 1600*1200 AA 4X:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
8. Code creatures 1600*1200 AA 4x sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
Code creature summary: even with an overpowered video card the maximum difference between the single channel socket 754 and the dual channel socket 939 is 5.9%, far below the 9.4% suggested by the PR of these processors.
Also despite being a Directx8 benchmark and using a radeon x1950 pro at 1600*1200 all 4 systems perform within 2% of each other! So a true directx8 card - such as geforce4 ti4600 - would give you horrendous performance; and it's 100% true - for high performance in Directx8 games you need a good Directx9 card; for high performance in DirectX7 games you need a good directX8 card and so on.
9. We switch to Aquamark3, the first DirectX9 benchmark to ever be released and start at default settings: 1024*768, AF 4X, no AA, no Sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
AV8 leads the pack even if by the tiniest of margins - the same happened with the code creatures results!
10. 1024*768 maxed out settings, including sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
For the first time ULI manages to score a victory by leading VIA with a very small margin!
11. We go up to 1280*1024, without sound first:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
12. ... and with sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
13. We reached the grand daddy of retro resolutions: 1600*1200
A. KU8
B. KV8 PRO
C. UL8
D. AV8
14. Final and most demanding settings: 1600*1200 max details with sound:
A. KU8
B. KV8 PRO
14. C. UL8
D. AV8
In Aquamark ULI manages to hold its own, buckling only at the 1600*1200 resolution! It's practically a toss-up. Again the difference between the dual channel and single channel Athlon 64 is 5% at most. There is no result until now that would validate the PR rating of the Athlon 64 3500!
15. 3dmark 2000, the only Directx7 test in the entire suite is next:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
VIA is starting strong, with a huge lead over both ULI systems! However performance for all 4 platforms is more than satisfactory for any Directx7 game.
16. 3dmark2000 - 1280*1024
A. KU8
B. KV8 PRO
C. UL8
D. AV8
17. 3dmark 2000 - 1600*1200
A. KU8
B. KV8 PRO
C. UL8
D. AV8
