Reply 20 of 37, by douglar
- l33t
tehsiggi wrote on 2026-03-06, 19:17:RandomStranger wrote on 2026-03-06, 18:45:High-balling the heat production is not a bad thing. It makes running these cards safer. If I'm replacing the factory original cooler I always replace it with something much higher performance.
Those numbers will stay in the internet and spread as "facts". Oversizing coolers is fine - spreading wrong numbers helps nobody.
I would also challenge if the small cooler (no3) can sink away 40W while the significantly larger (no4) can only do 50W - I have no3 here. If desired, I can try to qualify how it behaves at what wattage of heat.
I updated my post.
I would really love to have some numbers on these things though. It's a lot of guess work.
But then there are a lot of variables, like case ventilation, ambient temperature, and quality of thermal paste. Those things can make one man's silent PC into another's GPU grave yard.
