First post, by pete8475
- Oldbie
I spotted a 1GHZ socket 370 100MHZ FSB P3 on ebay a while back and bought it right away, finally got around to playing around with it a bit last night and today.
I also recently got a new old stock AOPEN QF50A beige case so I put the build in there.
Specs:
Intel Pentium 3 1GHZ (SL5QV)
Asus CUBX-E
512MB PC133 CL2 (2x256)
Geforce 5900XT 128MB
120GB Kingston SATA SSD
Sounblaster AWE64
3COM 10/100 ISA NIC
LG DVD-ROM
Belkin USB 2.0 card
EVGA 500W Power Supply
Windows 98SE
Obviously the video card is way overpowered for this processor but I wanted to see how the performance would scale up with some overclocking. 1241MHZ is the fastest I can get it to in this board, the next FSB choice is 133 and it does not post at that speed.
The Belkin USB card has an NEC chip and this one is nice because it does NOT negatively effect performance! I learned about this card here on vogons and bought several after that.
Anyway here are some basic benchmark results, I also ran the tests with my 128MB TI4200 to see how that compared to the 5900XT.
Also attached are some pics of the machine and CPU-Z.
3dmark99
ti4200 - 7545 - 1000mhz cpu - 45.23
ti4200 - 7306 - 1000mhz cpu - 56.64
ti4200 - 9315 - 1241mhz cpu - 45.23
fx5900xt - 4754 - 667mhz cpu
fx5900xt - 7170 - 1000mhz cpu
fx5900xt - 8017 - 1100mhz cpu
fx5900xt - 8905 - 1241mhz cpu
3dmark2000
ti4200 - 6893 - 1000mhz cpu - 45.23
ti4200 - 6799 - 1000mhz cpu - 56.64
ti4200 - 8574 - 1241mhz cpu - 45.23
fx5900xt - 4271 - 667mhz cpu
fx5900xt - 6480 - 1000mhz cpu
fx5900xt - 7290 - 1100mhz cpu
fx5900xt - 8249 - 1241mhz cpu
3dmark2001
ti4200 - 6410 - 1000mhz cpu - 45.23
ti4200 - 6251 - 1000mhz cpu - 56.64
ti4200 - 7697 - 1241mhz cpu - 45.23
fx5900xt - 4777 - 667mhz cpu
fx5900xt - 6601 - 1000mhz cpu
fx5900xt - 7234 - 1100mhz cpu
fx5900xt - 8024 - 1241mhz cpu
3dmark2003
ti4200 - 1155 - 1000mhz cpu - 45.23
ti4200 - 1146 - 1000mhz cpu - 56.64
ti4200 - 1247 - 1241mhz cpu - 45.23
fx5900xt - 3494 - 667mhz cpu
fx5900xt - 3851 - 1000mhz cpu
fx5900xt - 3940 - 1100mhz cpu
fx5900xt - 4044 - 1241mhz cpu
Quake 1
ti4200 - 321.8fps - 1000mhz cpu - 45.23
ti4200 - 297.7fps - 1000mhz cpu - 56.64
ti4200 - 376.1fps- 1241mhz cpu - 45.23
fx5900xt - 227.9fps - 667mhz cpu
fx5900xt - 334.3fps - 1000mhz cpu
fx5900xt - 359.5fps - 1100mhz cpu
fx5900xt - 395.0fps - 1241mhz cpu
Quake 3
ti4200 - 83.9fps - 1000mhz cpu - 45.23
ti4200 - 87.6fps - 1000mhz cpu - 56.64
ti4200 - 107.7fps - 1241mhz cpu - 45.23
fx5900xt - 51.6fps - 667mhz cpu
fx5900xt - 82.8fps - 1000mhz cpu
fx5900xt - 89.1fps - 1050mhz cpu
fx5900xt - 93.3fps - 1100mhz cpu
fx5900xt - 107.0fps - 1241mhz cpu
EDIT - added 667mhz results.
EDIT 2 - added 45.23 results for ti4200 at 1ghz cpu speed, I also went ahead and added 1241mhz results because it doesn't take long to do these tests.
aka pete4237.5
