Reply 20 of 23, by pete8475
- Oldbie
DaveDDS wrote on 2026-03-28, 20:41:Curious how you arrived at this? (I don't have a lot of experience with Athlons) […]
pete8475 wrote on 2026-03-28, 03:58:Well that would be because the KT133 chipset does NOT support 133FSB. ...
I don't see "KT133" within the original post.
The CPU specs page linked in that post says "AM1400AMS3C" and says it supports 200mhz bus.
The mainboard link also says 200.The wiki page you pointed to doesn't show bare "KT133" and other KTs go above 133.
Just curious - would like to understand Athlons better (I have one somewhere in a box - If I ever find a board that it works on I'd like to bring it up)
Well KT133 is the chipset used on the board OP has.
That chipset does 100MHZ FSB (aka 200 in AMD speak). The Athlon XP processors use a 133 (266 in AMD speak) FSB speed, even later Athlon XP processors have 166 (333) or 200 (400) FSB.
A lot of things in that era got weird when AMD started using model numbers like 2400+ instead of MHZ numbers.
EDIT - also in the wiki page KT133 is listed as Apollo KT133.
aka pete4237.5
