What PCI Express cards do you still use?
Reply 20 of 36, by robertmo3
GTX 10/16/20 series cards often do not work on older AM2/AM2+ motherboards, because the motherboard lacks UEFI firmware, relying instead on a "Legacy" BIOS. Modern NVIDIA GPUs require UEFI to initialize properly during boot.
Reply 21 of 36, by RetroGamer4Ever
Many old motherboards from the transition period have buggy UEFI implementation, so that too is a problem.
Reply 22 of 36, by cyclone3d
robertmo3 wrote on 2026-03-30, 14:19:
i tried gtx 1660 in a Phenom X4 9550 cpu, ASUS M2N-SLI Deluxe board (socket AM2) and it doesn't work. win11 works on that board though.
I bet that video card requires UEFI.
Or the board cannot map memory how it needs to for that video card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23 of 36, by momaka
robertmo3 wrote on 2026-03-30, 14:33:
Didn't know that, that's very interesting.
So I suppose this applies to most modern GPUs (anything DirectX 12 more or less)??
Last year I acquired a Radeon RX550 from the flea market and I couldn't get it working on two of my tests systems - one being an old socket 939 motherboard, the other a socket 775 system, and the last a AM2 system. Do you think/know if Radeon RX 5xx series also need UEFI BIOS in order to work? If so, perhaps that might explain why. Then again, most of the stuff I get from my local flea market don't work right (or at least not very frequently). Would be nice if the card actually worked... though I probably shouldn't get my hope up too much.
Anyways, thanks for sharing the above info.
Reply 24 of 36, by pete8475
The mains ones are:
GTX4070 12GB in my main "modern" pc
7800GTX in Pentium 4
4 port SATA card in TV PC
GTX980TI 6GB in XP PC
aka pete4237.5
Reply 25 of 36, by Blavius
I've built a new system recently (pre rampocalypse) and I only have two PCIe cards; a 5070TI and a SoundBlaster Audigy Rx.
To be honest, the SoundBlaster is more of a nostalgia totem, I've always had one in my machines since the 90's. In theory this card allows me to have EAX in old games, but I've been having too much fun playing new games, and this card doesn't add anything over the USB DAC (Dragonfly) I'm using atm.
I love expansion cards, but let's be real, for mainstream use there is not really any use beyond the GPU anymore.
Reply 26 of 36, by shevalier
momaka wrote on 2026-03-30, 21:12:
RX580 Sapphire pulse & GA-MA785-UD3 (Award bios PG6.0) work fine together.
https://winraid.level1techs.com/t/request-del … e-rx560/34936/5
https://winraid.level1techs.com/t/amd-and-nvi … uests-diy/30917
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 27 of 36, by RetroGamer4Ever
Other than GPUs, I have some USB 3.0 interface cards and an eSATA interface card. The move to USB 3.X and USB 3.X WiFi adapters has made many add-in cards superfluous.
Reply 28 of 36, by orcish75
Spread across my PCs and homelab are GPUs, 4 port gigabit and 10 gigabit LAN cards, LSI and Adaptec SAS RAID cards, Infiniband cards, USB 3.0 cards.
Reply 29 of 36, by momaka
shevalier wrote on 2026-03-31, 10:44:
OK, thank you for noting this.
In my case, I tested my RX550 0nly on PCI-E 16x gen 1 boards... but I doubt that was the issue. Will test on something a little newer (and with UEFI, just in case) when I have time, though I doubt that would change anything. I suspect I will be firing up the heatgun (and yeah, I know the chances of that "fixing" anything is quite low... but better than nothing.)
Reply 30 of 36, by RetroGamer4Ever
Only the newest RX cards (RDNA 4 and upcoming UDNA 1/RDNA 5) require UEFI, so you are fine to use any card from previous generations of RDNA on "Legacy systems".
Reply 31 of 36, by shevalier
momaka wrote on 2026-04-01, 17:41:
dont do this.
Its software problem
G41 PCI-e V1.1+ Asus AMI ( not UEFI)+ RX580
Reply 32 of 36, by SPBHM
I use a PCIE to NVME card! so I can connect an SSD to the PCIE slot.
Reply 33 of 36, by bitzu101
I use a wi fi card on PCIe.
Reply 34 of 36, by Intel486dx33
Creative is still making sound Blaster pci-e cards.
And I still use my PCI Creative Audigy 2zs in my daily driver windows-10 and Windows-11 computers.
Reply 35 of 36, by wiibur
GPvLAB RTX 4090 48GB video card, Datapath VisionRGB E1S capture card, RME HDSPe AIO sound card
Reply 36 of 36, by StriderTR
Just my GPU.
I've got a PCIe NVMe card, but it's not in use at the moment. I bought it to use as extra fast storage in a home game server, but ended up not needing it.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
