Reply 200 of 281, by Shponglefan
- l33t
DustyShinigami wrote on 2026-04-02, 15:27:I'm still not sure if my Yamaha YMF719E S supports intelligent mode...? Or is this where I would need to buy a Sound Blaster 16...?
EDIT: Okay, I'm getting the impression it does from a few posts I've seen online. Whew.
Neither of these cards support intelligent mode for MPU-401.
The only cards that do are either legacy Roland MIDI interface cards or compatible cards (e.g. Music Quest MQX-32M), Roland MPU-401AT, Roland LAPC-I (also requires a proprietary MIDI connector), Roland SCC-1 or SCC-1A,PicoGUS or the PCMIDI interfaces both available as a stand-alone MIDI interface or included on various bespoke cards like Orpheus, Orpheus II, MK1869 add-on, etc.
Using the MT-32 with pretty much anything else will require SoftMPU for cases where intelligent mode is required.
