First post, by dukeofurl
- Member
I recently got one of these inside an OEM PC. It currently has a pii 266 and a pci ati 3d rage pro. I'd like to upgrade it to increase the capabilities.
The board seems limited to a 66mhz fsb and as far as I've read, it is likely that it provides a non adjustable 2.0 v for cpus. I think the bios is also likely to be too early to support coppermine cpus, so I'm thinking the reasonable price best performance CPU I could run on this would be a 533 Mendocino celeron in a slocket. I'm new to messing around with slot 1, but my thought is I should just be able to get a cheap slocket without any jumpers as the CPU should take the same fsb and voltage that the motherboard already provides for the piis. Does that sound right?
I think upgrading the GPU would be very helpful for playing games. Conventional wisdom is that an agp GeForce card like a GeForce 2, would probably be the best bang for my buck, but as I research this board, I've seen comments that it is one of the earliest boards with an agp slot and may have issues with certain cards that draw more power than others. Nvidia was also cryptically mentioned in ancient forum posts as a manufacturer whose cards may have issues with the agp slot. Before I buy a card, does anyone have 2 cents on this matter? Should I just get a pci version to avoid this potential incompatibility?
