FTP2P is a dual-pane FTP client for MS-DOS
First post, by radozd
https://github.com/radozd/ftp2p
The attachment ftp2p.png is no longer available
Working with real DOS machines on modern networks is often inconvenient.
While TCP/IP stacks such as mTCP provide the necessary networking functionality, there is still a noticeable lack of practical FTP clients for DOS.
FTP2P was created to address this gap. The goal of the project is to provide a simple and convenient dual-pane FTP client for DOS systems, making it easier to browse local and remote directories and transfer files between them.
Feel free to report any issues 😀
Reply 1 of 36, by Mr.Hunt
Hallelujah! 🔥🔥🔥
Reply 2 of 36, by Yoghoo
Nice to see this. Did a quick test and it works really well. Some feature requests:
  • A refresh option would be nice (when removing/adding some files/directories while running the program)
  • Multi select for bulk actions like upload, download and remove (with INS key etc)
  • Option to change window position (I like the ftp server on the right 😀)
  • An option to start the app and get a window for the connection options in the app
  • A config file to save the connection information (and option to ask for password if you don't want to save it)
  • With a config file in place maybe an option to select different servers within the app (close connection; connect to new server etc)
I made a similar program for EtherDFS in the past so these features are mostly copy/paste from a list I made before. 😜
Reply 3 of 36, by radozd
Yoghoo wrote on 2026-04-01, 10:15:
[*]A config file to save the connection information (and option to ask for password if you don't want to save it) [*]With a conf […]
[*]With a config file in place maybe an option to select different servers within the app (close connection; connect to new server etc)
[/list]
I use a customized Dos Navigator menu with preconfigured servers. Some of them have the password specified right away, while others do not.
As an alternative, you could use choice-like utilities together with a batch file.
The one truly essential feature here is multiple selection, no question about it.
But I wanted to finish it by April 1 and not dig myself in any deeper.
Reply 4 of 36, by fix_metal
Wow. Great idea, Can't wait to test this. The ftp client for wfw3.11 I've got always generates a error when opening a remote dir. Odd enough, it's 1 error generated per file in the remote dir, and I have to click IGNORE for all of them, anytime if I acknowledge, it just crashes.
Reply 5 of 36, by radozd
v2
You can select multiple files at once and copy or delete them in one go.
I think this is mostly enough for now. From here on, it’ll probably just be bug fixes, if any turn up.
Reply 6 of 36, by keropi
oh this is nice, will test it next time I want to transfer some files!
Reply 8 of 36, by Falcosoft
For me the 150 maximum item count seems to be overly restrictive. Can it be increased to at least 512 or rather make UI_MAX_ITEMS to be a command line parameter instead of a fixed define?
The main problem is that because of this limit many directories are not even listed.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 9 of 36, by Grzyb
Falcosoft wrote on 2026-04-03, 23:30:
Indeed.
Norton Commander 5.51 for DOS can do more, even in reduced-memory-usage modes:
        Command Line            Description
nc /s Launch Commander with SMALL memory
configuration. Number of files per panel
is 700.
nc /t Launch Commander with TINY memory
is 300.
Reply 10 of 36, by radozd
Norton don't have to handle long filenames / utf8.
I'll see what I can do.
Reply 11 of 36, by Grzyb
radozd wrote on 2026-04-04, 02:22:
NC 5.5/5.51 does support LFN where the LFN API is available, eg. under Windows 9x.
But I don't know how it affects the maximum number of files per panel...
Anyway, nice to see such an utility - for a long time, it's been like the Holy Grail for many people!
Reply 12 of 36, by radozd
Given the item size, the limit can be increased to 400 files without effort. I hope it will be enough.
I don't want to make this part dynamic yet(?)
Reply 13 of 36, by Grzyb
So I've downloaded a 100 MB file on my 286 box - which naturally took a while, but completed successfully... almost.
After the download, I can see "Timeout", and can't see the downloaded file in the local panel - it's not refreshed.
But if I refresh it manually, I can see the file.
I've even tested the file's integrity - perfectly fine.
Reply 14 of 36, by radozd
Thanks for the report.
The issue has already been fixed and committed, but the fix hasn’t been released yet. A global transfer timeout was a bad idea.
Reply 15 of 36, by Falcosoft
radozd wrote on 2026-04-04, 05:52:
Yes, 400 items would be much better.I have noticed that in your commit description you mentioned the limit change to 400. But in the modified code I found this:
#define UI_MAX_ITEMS          (300)
On my server currently I have ~360 files/directories in the root. So 400 would be just enough but only 300 not really.
Website, Youtube
Reply 16 of 36, by radozd
It will be 400, don't worry.
I'm focused on testing the timeouts now.
Reply 17 of 36, by radozd
Look ok to me. You may try 2.1
Reply 19 of 36, by radozd
Version 3 is here
I'm not entirely sure why I keep doing this, but I seem to get a kind of forgotten enjoyment from exploring old FTP servers.
