RetroPCCupboard wrote on Today, 05:07:
A long time ago the retro community began steering away from all period correct parts.
Gotek floppy emulators, CF and SD cards as storage, IDE to SATA converters, XT-IDE, LCD screens, modern ISA soundcards (adlib clones, PicoGUS, Orpheus II).
The latest things are optical drive emulators and even ROM BIOS emulators. You can even buy gadgets that are supposed to sound like hard drive activity.
But there are several nuances, too. There are AdLib clones and AdLib replicas, for example.
The replicas are using the real old tech and are nearly indistinguishable from"originals".
And then there are emulation projects, such as PicoGUS, of course.
Which I personally try to avoid, because I want real hardware in my hardware projects.
I love emulation, really, but if I need emulation I rather decide to use a fine emulator.
The there's storage. SD/TF an MMC cards are fairly new, but other flash types are period-correct.
CF cards, DOMs and DOCs existed in the 90s. I have internet set-top boxes that have them inside and run DOS (ca. 16 to 64 MB).
Also, the hard disk always came in different forms. Even in the 1980s, some PC emulators on the Amiga used hard files to simulate a PC's HDD.
LCD screens existed since the 1980s, but mostly on laptops and portables.
My Compaq SLT 286 was from 1988 and had a 640x480 pixel VGA screen, for example.
DOS games usually expect a 4:3 CRT color monitor with a poor dot pitch and a screen mask.
IDE to SATA converters are protocol converters and not so much emulation in a narrow sense, I think.
Early SCSI drives used ESDI HDDs with a converter board, for example.
A valid point are drive emulators for removable media, such as Goteks.
However, I think that DOS or Amiga fans don't substitute real floppy drives for Goteks.
They rather keep the real drives and floppies around for special occations and use the Goteks as an addition, as a "nice to have" kind of extra.
