First post, by DustyShinigami
- Oldbie
Similar to this thread - Win 98SE hangs on shutdown - I also randomly get hangs when Windows tries to shutdown. It usually gets to the Windows 98 logo and says 'system is shutting down' and then does nothing. I've got Windows to create a bootlog, though ironically, when I shutdown, it shutdown perfectly fine. Is there a way of getting Windows to generate a boot log every boot automatically? So when it does hang again, I can more easily pin-point the cause. Or is it a matter of having to do it manually each time? With my custom boot menu, pressing Shift and F8 doesn't appear to do anything, so I've had to re-enable the default one so I can pick it from the list.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
