First post, by ott
Hi, I have ASUS P2-99 motherboard [TRW] (Rev 1.12 without HW monitor, 440ZX chipset), everything works fine except for one problem:
- When AC power is applied to the PSU for first time, the motherboard turns on by itself for half second and then immediately turns off.
Next power-ups with PWR_SW button work without issue as long as the standby power is present.
If the AC power is disconnected for more than 10 seconds, the problem recurs.
Forums say this is normal behavior for some ASUS and Intel motherboards, but I can't find official proof from ASUS or Intel.
If you have any related doc, please share.
I had almost resigned myself to this problem, but a year ago I found the same ASUS P2-99 board/revision on marketplace and the seller made a video confirming that this problem does not affect his board.
I wanted to buy, but I got another board with 440BX chipset (there is no such problem either).
I'd like to understand the cause of this behavior and, if possible, fix this bug.
