First post, by fjasper
Yesterday I tried to install Venture Publisher 3.0 (MS-Dos Version) on Dosbox.
The installation starts nicely and I mount the second disk.
But then it asks for disk 3 "Ventura publisher utilities disk #3" and the disk does not seem to be recognized.
Dosbox mounts the image of disk 3 properly but the Ventura setup keeps asking for disk 3.
I got the files from https://winworldpc.com/product/ventura-publis β¦ /30-for-dos-gem
The Homepage states it is the version from http://archive.org/details/IBM_PC_Compatibles β¦ OSEC_2012_04_23
which I tried as well.
So, in short, could someone replicate my diffculties or give me a hint if I am doing something wrong?
Maybe the image files are not correct although I can see the contents of the image and it is mounted without error?
Or even better, maybe someone could help me out with a version of Ventura Publisher MS-Dos which works?
Any help would be greatly appreciated π
Played around with the software for a while but right now I am running out of ideas π
Wanted to install the software on my 286 machine after I got it running on dosbox....
Best Wishes from Germany,
Fabian
