I did a another test on Asus K8N-E (nForce3 250Gb chipset) and Turion 64 ML-34. Arctic Freezer 64 pro was used directly on die, mounted on the original plastic frame with steel backplate. This time heatsink pressure is sufficient probably due to steel backplate and slightly different plastic frame. No copper shim is needed for long term usage.
CPU runs fine at 2200Mhz, 259Mhz base, 8.5x multiplier, HT 777 (3x), 400 memory (divisor 11). AIDA64 shows memory latency 66ns, which is equivalent to Clawhammer 3400+. We got 4ns less than MSI K8T Neo V. It is probably possible to go lower by tightening memory timings, this was not done due to time constraints.
- even latest BIOS doesn't like 2 memory sticks and Memclock Value 400. It automatically lowers it to 333 even if nothing is OCed. With one stick it allows 400. We can still reach DDR 400 by using 333 and higher CPU FSB Frequency though.
- BIOS detects the CPU correctly as AMD Turion(tm) 64 Mobile Technology ML-34
- BIOS setup allows changing CPU voltage (FID/VID Change set to Manual), I used 1.4V. Beware, when switching to manual voltage BIOS suggests 1.5V.
- CPU FSB Frequency was set to 259. Maximum stable FSB is 275. 277 doesn't boot to BIOS at all.
- CPU multiplier 8.5x is available in BIOS setup
- DRAM clock 333 was used in BIOS for 11 memory divisor. Higher clock results in too low divisor. DRAM clock 266 results in divisor 14 which is too high.
- Hypertransport multiplier was set to 3x
- CAS latency was left on auto
- Cool'n'Quiet Support was disabled
- With prime95 running, CPU temperature was 37'C due to less CPU voltage.
- Chipset runs very hot, I would highly recommend mounting a little fan.
The following memory divisors are possible for Turion 64 ML-34 based on CPU multiplier and Memclock Value in BIOS:
- 9x CPU multiplier - memory divisor 11 (Memclock Value 333) or 14 (Memclock Value 266)
- 8.5x CPU multiplier - memory divisor 11 (Memclock Value 333) or 13 (Memclock Value 266)
- 8x CPU multiplier - memory divisor 10 (Memclock Value 333) or 12 (Memclock Value 266)
8x CPU multiplier is impractical as we are limited by CPU FSB 275. Real memory speed is also too low as a result. I updated previous post with suggested frequencies as memory divisor 12 isn't practical. This complicates running at 2.4Ghz as OCing memory is unavoidable.
It passed 30 minutes run of prime95 (L1/L2 stress) at 2.4Ghz (ddr speed set to 266 conservatively in BIOS). CPU is prime95 stable at 2475Mhz (275 x 9) and 1.4V too. I didn't test lower voltage. It is the maximum frequency Turion 64 ML-34 can achieve on this board due to CPU FSB limit and 9x CPU multiplier. Turion 64 ML-37 would be needed to go higher, but those are unavailable. True ceiling thus cannot be determined.
The best options for Asus K8N-E and Turion 64 ML-34 are:
- 2200Mhz CPU, 259Mhz base, 8.5x multiplier, HT 777 (3x), 400 memory (divisor 11, Memclock Value 333 in BIOS) <-- good pick, will be equal to Clawhammer 3400+, but with SSE3 and lower TDP
- 2270Mhz CPU, 267Mhz base, 8.5x multiplier, HT 801 (3x), 412 memory (divisor 11, Memclock Value 333 in BIOS) - slight memory OC
- 2403Mhz CPU, 267Mhz base, 9x multiplier, HT 801 (3x), 437 memory (divisor 11, Memclock Value 333 in BIOS) - high memory OC <-- top performance, will beat Clawhammer 3700+
At DDR 406, CL2 could no longer be used, CL2.5 was needed. The system could boot Windows XP at DDR 437@2.7V and relaxed timings, but was not stable. The other two options are probably not worth the time and risk.
Based on my observations I would recommend to go with the first option, Memory OC is problematic and requires lot of tinkering with timings and memtesting. That limits CPU frequency to 2.2Ghz due to memory divisor 11. To make use of memory divisor 12, we would need CPU frequency 2.4Ghz and CPU FSB 300, far beyond the max stable value 275. To make use of memory divisor 13, we would need CPU frequency 2.6Ghz and CPU FSB 306 which is far beyond the max stable value 275.
Turion 64 ML-34 is a good replacement for Clawhammer 3400+, supports SSE3 and has lower TDP. It is widely available and cheap.
Turion 64 ML-37 unlocks multipliers up to 10x and another interesting option becomes possible:
2403Mhz CPU, 253Mhz base, 9.5x multiplier, HT 758 (3x), 400 memory (divisor 12, Memclock Value 333 in BIOS) - replacement of Clawhammer 3700+
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
