First post, by BerkeleyGamecat
I've been refurbing an old Compaq Presario XE that has started to develop corrosion on the mobo. After removing the old lithium battery and cleaning up some minor spots of residue, I pulled the SIMMS and found that two of the four (those with silver contacts, but not the ones with copper contacts) had a fair amount of corrosion on the contacts.
After cleaning them with a stiff nylon brush I noticed that a fair amount of surface plating has been removed. The underlying contacts are still conductive. Is there something I need to do about this, or is this even something to worry about?
Reply 1 of 6, by Thermalwrong
You could re-tin the contacts with fresh solder and then use solder braid to make the contacts flat again. That should improve the contact reliability.
The nice thing with tin plated SIMM contacts 😀
Otherwise you could probably clean it back a bit more, I use a ceramic tool to scrape off corrosion like that. You don't need to worry until you see copper, at which point stop. Then you might need to re-tin the pad.
Reply 2 of 6, by BerkeleyGamecat
Thermalwrong wrote on 2026-04-09, 13:38:
You could re-tin the contacts with fresh solder and then use solder braid to make the contacts flat again. That should improve the contact reliability...
Thanks Thermalwrong. I may try re-tinning at some later date, but right now I have too much going on to spend time developing a new skill.
I brushed them a bit more and cleaned the socket before shoving them back in. System ran the Compaq memory torture test for 1.5 hours with no errors, so I guess everything must be connecting ok for now.
Just curious - do you know why they made them that way? Copper connectors seem to not be susceptible to the same kind of corrosion, but maybe they cost more to make?
Reply 3 of 6, by fix_metal
Copper oxidize faster when in open air. Back in the days when I etched PCB I would always tin the traces myself.
Then, one would argue that silver is a better conductor than copper, but also bad at surviving oxides. But you know, makers don't create things to last 30+ years: the market is meant to make you consume and replace superseded or broken objects. My 2 cents is they simply got engineered for the moment.
Reply 4 of 6, by HwAoRrDk
BerkeleyGamecat wrote on 2026-04-10, 04:59:
To start with, those other kind of connection contacts aren't copper (well, technically they are - they all are - just not the surface finish, which is what we're talking about here). They are either gold-plated (a.k.a. "hard gold") or nickel-gold plated (a.k.a. ENIG). If they were bare copper, they would very quickly oxidise and corrode (a.k.a. the "green crusties") within months or even weeks.
They use tin-coated contacts simply because it's cheaper than gold, even though it's an objectively worse contact finish.
Reply 5 of 6, by BerkeleyGamecat
HwAoRrDk wrote on 2026-04-10, 15:30:
To start with, those other kind of connection contacts aren't copper (well, technically they are - they all are - just not the surface finish, which is what we're talking about here). They are either gold-plated (a.k.a. "hard gold") or nickel-gold plated (a.k.a. ENIG)...
So... gold?
