Most pick anti-static bubble wraps is generally safe for shipping electronics, with two big caveats.
1. Just becasue it's pink, does not guarantee it's anti-static. You can buy colored bubble wrap, including pink, that's just plain bubble wrap.
2. Unlike anti-static bags that have an external conductive layer, anti-static bubble wrap works by pulling small amounts of moisture out of the air to make the exposed surface conductive and reduce the buildup of a static charge. No moisture, no ESD protection.
That being said, you should be able to rub an anti-static bag on your head on all day and it should never hold a charge, wet or dry. If you do this with ESD safe bubble wrap, your hair and friction will remove the surface moisture and allow it to hold a charge until that moisture is replenished.
Me personally. I always store and ship in anti-static bags, then covered in bubble wrap if needed. For maximum protection, I've also used anti-static bags infused with bubble wrap that has a physical conductive layer, one that does not rely on moisture like the pink stuff. Many modern video cards are shipped and stored this way. However, it's obviously more expensive. Though, I would never ship RAM, or any other sensitive electronic components, with just bubble wrap. Anti-static bags are super cheap.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
