Reply 1820 of 2029, by NeoG_
theelf wrote on 2026-04-14, 07:30:Hi thanks fo reply!!, im in DOS, using for playback, quickview pro […]
polpo wrote on 2026-04-14, 00:02:Are you in DOS? Windows?
- Picogus is in USB mode
- Video is a Cinepack 12fps, 320x200 video, tried ADPCM 22khz mono audio or PCM 8bit 11khz, interleave every frame. Video is 40min long, 560mb, then 230-250kb sec
- Tried too msvideo 1 256colors, 12fps, same audio options and interleave, 640mb more or less 270kb sec
- Tried iso and cue/binBot videos i burn in CD and test in a 4x IDE drive and play fine, from HDD too
Using Picogus CD give me stops every 2 or 3 seconds because frameskip
NeoG_ wrote on 2026-04-13, 23:16:Check your transfer speed from the virtual drive using something like speedsys, if it's running at full speed it should be able to get 3.5x with bin/cue images and 4.5x for ISO images. I had some settings in the BIOS like IO recovery period which was slowing down the virtual drive speed but still allowed the audio side to work fine.
Hi! i get consistent 600kb sec transfer rates in speedsys, and i can confirm by copy a file in DOS is correct
In fact my IDE 4x drive is slower, because i think i use CDRW unit and the unit is old, read at 360-420kb sec, but anyways video play smooth from real CD
I dont have a IO recovery period option in bios
thanks!
I wonder if the MKE cdrom has naturally higher CPU overhead and its running out of CPU power to copy from ISA bus and decode at the same time
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
