TEDIT v0.72 [CFG SAVE DIR]
Reply 140 of 171, by aVd
Just tested TEDIT 0.69 with "mixed" LF+CR,LF text file. So, it reads the line break from the first line and sets it as standard for the opened file, then on save it writes line breaks according to this. Seems Ok to me.
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
Reply 141 of 171, by DaveDDS
aVd wrote on 2026-04-05, 13:31:
... it reads the line break from the first line and sets it as standard for the opened file, then on save it writes line breaks according to this ...
Given "8086 16-bit", screenshots and lots mention of "DOS" in this thread, I've been assuming that this IS a DOS editor.
In which case I don't see a reason to set the type of line-break writtene to files.
IMHO a DOS text editor should write standard DOS text files (ie: CR,LF line-breaks)
I get that a single LF is prefferable, but DOS was written in the days where everything was oriented to what could be sent directly to a terminal or printer without all that excessive "processing" needed to make it truly printable.
I do find it annoying when I have to work with a text file from *nix with some DOS software that insists on the CR,LF and doesn't understand text files from better OSs, so you have to "convert" it.
What I do personally is my DOS editor uses newline (LF) and ignores CR when reading - so it has no trouble understanding files of either line-break type (it can even deal with files that are LF,CR - which were used in some classic OSs)
When writing the file, it used DOS standard line-breaks. So... when I get a *nix file with only LFs, I just have to load it into my editor and resave it to make it fully compatible with all DOS software.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 142 of 171, by aVd
Hi, @DaveDDS,
Latest version of TEDIT "understands" perfectly fine those two standards for line break. It visualizes them correctly even in "mixed" text files. Yes, it's a DOS text editor, but modern one, and it's nice to have this conversion feature.
Let's assume, that we have a rare case of DOSBox in Linux and have to edit a *nix text file - why changing its standard by default? If we need to do so - there's a conversion option in the menu (and possibly a keyboard shortcut in the future - some Fn key for example).
P.S. Maybe "LF" is more preferable (and saves some bytes), but when using DOS/windows it's not, and I don't like to see a source code for DOS/windows programs written in *nix environment with no respect for different line break standard 😀
Reply 143 of 171, by DaveDDS
Good point - I hadn't though about DosBox on *nix ...
If would be ideal if DosBox itself could handle the conversion, but I don't think this is really possible since text/binary file access mode isn't handled by DOS itself in so many cases.
A lot depends on the development tools used to write DOS programs. I've run into a *lot* of DOS software which works with text files and just can't handle them without CR,LF line-breaks.
If you move things back and forth between DOS/Win and *nix, you really need to get proficient at converting. This is why my DOS "CP" (copy) command has a -U option to convert line-breaks to<>from Unix line-breaks.
But... being a "purist", I still think that DOS software should write DOS standard text files (with perhaps an option to write *nix).
It really becomes a question of why you are accessing host files within DosBox if not to use them ongoing in DOS... Why would you fire up DosBox just to edit a host file? I would think "to use it with DOS stuff" would be a more common answer than "I just like editing in DOS more"
Reply 144 of 171, by aVd
I fully agree with your "purist" attitude, @DaveDDS. And that's why I think, that TEDIT shouldn't mess with the text file line breaks, if not explicitly forced to do so. I often use DOSBox in Linux for quick tests of different DOS programs or even different DOS versions (it can be "rebooted" with option to load OS from mounted floppy or HDD image). For example, when DOSBox is used in full screen mode, sometimes it's faster to use m$ EDIT or other DOS text editor to change something in CONFIG.SYS and AUTOEXEC.BAT, than "switching back" to host OS, starting file manager, browsing for the file... etc.
Maybe an indicator with red background for "LF" (*nix standard) will be more cautious, than the current one. Just to remind to user, that currently edited file is not of a DOS/windows standard.
Reply 145 of 171, by DaveDDS
I guess we have a different idea of what "purist" means. To me it means DOS stuff should write DOS compatible text files. To you it means DOS stuff shouldn't change the format of text files - both are valid viewpoints and there are cases where you want either behavious. (really the only thing that sightly favors mine is that the code would suffer some bloat in dealing with files it should never see in DOS, and yours is that text files not for to DOS wouldn't get slightly bigger)
I can think of one case where I write a file to be used omn the host from within DosBox - I have tools to update the DosBox configuratuib file from within DosBox (this is why my edition of DosBox uses "DOSBOX.INI" instead of "DOSBOX.CONF" -avoid long filename which some DOS tools can't handle.
I've not run into problems because I rarely use Linux - I boot it in VMWARE sometimes (and actually have one physical Linux system) which I do only when I want to test something.
I've not tried, hopefully DosBox itself can read a configuration file with either type of line-breaks.
I do like the idea of showing a more prominent indicator that the file you are editing is non-DOS-standard format.
Reply 146 of 171, by cookertron
Release 0.70: https://github.com/cookertron/TEDIT
  • Swap files now hidden in a _TEDIT directory with a hidden attribute applied - can be viewed using /ah on the DIR command. _TEDIT is deleted on successful exit
Might be worth noting for anyone testing under DOSBox(-X) and using a mounted host folder, hidden directories don't work so _TEDIT will be visible if you shell to DOS and view the directory listing.
I haven't forgotten the other things you wanted. I've just been running a side project that has taken my attention a little bit.
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 147 of 171, by aVd
Hi, @cookertron,
The new hidden swap files enhancement seems to work fine.
Thank you!
P.S. Just saw, that you have updated Agent86 compiler too.
Reply 148 of 171, by cookertron
aVd wrote on 2026-04-14, 09:53:
Hi, @cookertron, The new hidden swap files enhancement seems to work fine. […]
Hi, @cookertron,
Thank you!
Yeah there were a couple of bugs that went undiscovered. The JIT compiler was completely broken in Linux which I've only just discovered having switched to Ubuntu to run other projects. The Windows binary hasn't been updated yet because I've not touched Windows for the last two weeks.
Three new features coming to TEDIT soon 😁
Reply 149 of 171, by cookertron
Release 0.71: https://github.com/cookertron/TEDIT
  • A recent file history in the file menu, sorted descending - most recent at the top. Saved to TEDIT.CFG.
  • Moved load/save project to options.
  • Clock in bottom right corner. Can toggle on/off in the settings.
  • TAB length, Shell memory dump, Show clock options saved to TEDIT.CFG using settings dialog box.
The attachment tedit_002.png is no longer available
Reply 150 of 171, by Yoghoo
Thanks! Didn't find any issues during testing on a retro pc.
Reply 151 of 171, by aVd
Awesome! I just made a quick test and the config-file settings work as expected (command line switches for tabs and memory swapping overrides the config-file saved settings temporarily - only if they are not changed again from the "Settings..." menu).
I have some proposals for a couple of small menu-items tweaks here and there, but I'll write about them tomorrow, as they need a pictured examples.
Reply 152 of 171, by igully
@cookertron
Thank you for the updates and new features.
An issue I came across:
I booted from a floppy drive (drive A:) that had TEDIT 0.71 and started developing on drive C:. I wanted to read some values from my active config.sys at drive A: so I loaded TEDIT and went to "Open...". I edited the Filename "*.TXT" in the dialog to "A:\*.*" and the Files box updated the contents, but the Directories box was kept listing the C: drive. Anyway, I attempted to load the config.sys file and I got an Error window "Cannot open file".
However, if I just use the command line interface it has no issues.
Reply 153 of 171, by DOSJunkie
When I look at the Borland C++ IDE (please see screenshot), there are also several editor options there that serve as inspiration and should be relatively straightforward to implement, for example:
- Autoindent mode (when you press Enter, the cursor jumps to the same column position as the first character of the previous non-empty line)
- Use tab character (inserts a true tab character #9, or inserts spaces if disabled)
- Cursor through tabs (determines whether the cursor can navigate through tabs character by character)
- Group undo (determines whether only the last command or the last group of commands can be undone)
- Persistent blocks (a block remains selected until it is deleted, another block is selected, or the selection is explicitly removed. If disabled, the selection is removed from a block when the cursor is moved out of the block)
I am aware, however, that there is a size limit for COM files and that not all suggestions can be included.
Reply 154 of 171, by aVd
igully wrote on 2026-04-16, 09:33:
Hi, Ignacio,
Did you tested how the TEDIT behaves when floppy disk is write protected, so no-swap files can be created, or what's happening, when diskette is almost full and there is not enough space for a new swap-file to be created?
Reply 155 of 171, by igully
aVd wrote on 2026-04-16, 11:32:
Hi, Ignacio,
Hi aVd,
Floppy is read and write, but being a floppy it is already limited on space. I would expect TEDIT should adapt and simply work out of the box to load a 4KB config.sys file. In any case the free space on the floppy was over 100KB for sure, which seems more than reasonable to view a single 4KB file. And the C: drive had several GB of free space.
Reply 156 of 171, by aVd
igully wrote on 2026-04-16, 12:01:
Hi aVd,
TEDIT is 8088/86 compatible, which means it may be used in some very old systems without HDD installed. I was just curious, if it handles those potential floppy related errors properly.
Reply 157 of 171, by Yoghoo
aVd wrote on 2026-04-16, 15:30:
Hi aVd,
It doesn't give an error when trying to save the config options on a write-protected floppy. But of course it doesn't save it either.
Can confirm that opening a file from the C: drive when running the editor from a floppy does not load the text file. It give the error: Cannot open file.
Reply 158 of 171, by aVd
Yoghoo wrote on 2026-04-16, 16:27:
Yep, this definitely will need fixing. At least some error message. Possibly the swap files creation fail will need a message too.
Reply 159 of 171, by igully
@cookertron
A couple of things:
1. The documentation (README.md) does not mention the TEDIT.CFG file creation and its purpose. It also does not mention that hidden _TEDIT dir.
2.Working on read-only media (like a CD-ROM) and on restricted space should be a consideration (not creating any file or hidden directory). This could be user selectable via Options menu or an autosense feature when media is read-only or less than N amount of space is free on the opened file drive. I see many cases where someone would open a tiny text file just to view it, and not to edit it.
3. All temporary files and directories should be ideally stored by default on TEMP and/or TMP as set in config.sys or autoexec.bat like many DOS programs do.
Thanks!
