First post, by sofakng
What’s the best way to connect a modern PC (ie. RTX 4090) to a PC CRT (VGA/DB15) ?
Probably best using an unbuffered converter, these ones are used in the arcade community
https://www.amazon.com/gp/product/B01B7CEOVK/ … e?ie=UTF8&psc=1
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
StarTech dp2vgahd20 works for me ... ~375mhz pixel clock (~ because some can apparently push higher due to silicon lottery on the DAC) if you need it for higher resolutions/refresh rates
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
