Reply 58740 of 58761, by marxveix
Shader_BiH wrote on 2026-04-13, 11:23:I've experienced this first hand... I got myself recently a Compaq Deskpro SFF with Celeron at around 200 MHz, and it had integrated Rage Pro Turbo (I suppose that is considered Rage 3?) It is indeed better, image quality is much better. I suppose a discrete Pro Turbo would also be faster. Do you have any advice concerning drivers for these... because I had many problems getting them right. Are they manufacturer dependant?
Use my Rage3 drivers if you want, they are the latest that work with ATi CIF, ATi Rage Pro Acceleration works at DDraw/3DCIF/Direct3D/OpenGL/GLUT/DVD + has GlideWrapper.
If this is RagePro or some other Rage3 AGP / PCI card, then drivers will work. These drivers only dont work with later released RageXL PCI (4752) and RageXC PCI (4753) i think.
Latest 5.40x modified drivers here:
Re: ATi RagePro drivers and software
download/file.php?id=239658
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
