A company I did some work for had an "AASTRA" VOIP PBX that they decided to decomission so I brought it home.
You can see it here: Re: Using XT-IDE on 386 with Compact Flash larger than 512MB - My tests.
Turned out its' built on a "PC compatible chassis" which ran XP internally. Perhaps your PBX is set up in a similar fashion.
Although the're normally never used, it has Ps2 keyboard/mouse ports and a VGA output (If no Ps2 ... perhaps USB might work on yours?)
If you connect a monitor and keybaord, you can actually see it boot and that it has a BIOS you can enter.
It had an internal proprietary 1-2G flash card, but underneath that was an CF socket. There was no obvious way to "install" an OS, but turns out it did recognize and boot from a USB floppy drive (maybe a bootable stick would have worked as well - I never tried).
I put a CF card in it and was able to installed DOS booted from floppy. I was able to find a packet driver that works with the built in network interface.
The BIOS does recognize USB sticks and presents them to DOS as hard drives.
So it has become a fairly useful little super-quiet DOS system (no fans or spinning rust).
Hopefully you can make use of yours in a similar way!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
