First post, by Jackhead
- Oldbie
I like to install a dual Tualatin system with windows 2000 SP4.
As Board i use a Asus TR-DLS. SCSI and Onboard graphics are jumped to disabled on the mainboard.
After the win2k setup is complete i got a error 12 code in the device Manager on the PCI bridge.
Meaning i dont have enough ressources???
I use a PCI GPU on the first 66MHz slot, and yes the GPU are able to run 66MHz.
All other drivers from win2k works fine with the chipset. So for Intel you have as always to install chipsetdriver.
For the ServerWorks CHipset are no drivers, because they include in win2k?
I tryed install win2k with (F5) MPS and ACPI, both same pci bridge problem.
Did i miss something?
