Reply 1240 of 1261, by ViTi95
Oh, I forgot to mention that all those numbers are indeed FPS (frames per second). 'i486' refers to the old code, 'Pentium' to the new code, and the percentage shows the comparison between the old and new code.
https://www.youtube.com/@viti95
Reply 1241 of 1261, by BinaryDemon
Awesome work all around but those IDT WinChip results are ridiculous.
Reply 1242 of 1261, by appiah4
ViTi95 wrote on 2025-10-07, 09:59:
Hi everyone! […]
Hi everyone!
After some time without posting updates here, I’ve got something I think is quite interesting. I’ve been reviewing the span rendering code (R_DrawSpan...) for the backbuffered and VBE2 direct modes, and I managed to create a new optimized version specifically for Pentium processors.
On Pentium CPUs, the SHLD instruction is quite slow (4 cycles) and cannot be paired with other instructions in the U and V pipelines. So what I did was to create a new version that replaces those instructions with simpler combinations that can pair in the U and V pipes (MOV, SHL, AND, OR, etc.). Here are the results I’ve obtained:
Pentium 75:
- FDOOM13H i486: 67.670
- FDOOM13H Pentium: 72.109 (+6.5%)
- FDOOMVBR i486: 80.050
- FDOOMVBR Pentium: 86.337 (+7.8%)
Pentium 100:
- FDOOM13H i486: 85.518
- FDOOM13H Pentium: 90.985 (+6.3%)
- FDOOMVBR i486: 111.096
- FDOOMVBR Pentium: 119.862 (+7.8%)
Pentium 133:
- FDOOM13H i486: 95.349
- FDOOM13H Pentium: 99.196 (+4.0%)
- FDOOMVBR i486: 127.431
- FDOOMVBR Pentium: 134.398 (+5.4%)
Pentium 166:
- FDOOM13H i486: 101.201
- FDOOM13H Pentium: 102.583 (+1.3%)
- FDOOMVBR i486: 139.099
- FDOOMVBR Pentium: 140.108 (+0.7%)
Pentium 200:
- FDOOM13H i486: 110.371
- FDOOM13H Pentium: 110.012 (−0.4%)
- FDOOMVBR i486: 158.691
- FDOOMVBR Pentium: 157.032 (−1.1%)
Analyzing the results, it seems that the new code performs well, but the speedup decreases as CPU frequency increases, even becoming slightly slower on the Pentium 200. This made me think “maybe I’m hitting an architectural bottleneck”, so I decided to test on the Pentium MMX:
Pentium 166 MMX:
- FDOOM13H i486: 105.628
- FDOOM13H Pentium: 110.551 (+4.6%)
- FDOOMVBR i486: 148.413
- FDOOMVBR Pentium: 156.668 (+5.5%)
Pentium 200 MMX:
- FDOOM13H i486: 115.264
- FDOOM13H Pentium: 118.393 (+2.7%)
- FDOOMVBR i486: 169.006
- FDOOMVBR Pentium: 175.136 (+3.6%)
Indeed, the MMX models seems to solve the bottleneck issue that affects the non-MMX models. I also ran tests on other architectures; some with good results, others not so good:
IBM 6x86 PR166+ (133MHz):
- FDOOM13H i486: 92.227
- FDOOM13H Pentium: 93.502 (+1.3%)
- FDOOMVBR i486: 119.018
- FDOOMVBR Pentium: 120.934 (+1.6%)
AMD K5 PR100 (SSA5, 100MHz):
- FDOOM13H i486: 74.988
- FDOOM13H Pentium: 74.822 (−0.3%)
- FDOOMVBR i486: 88.775
- FDOOMVBR Pentium: 88.311 (−0.6%)
AMD K5 PR133 (5k86, 100MHz):
- FDOOM13H i486: 96.094
- FDOOM13H Pentium: 95.822 (−0.3%)
- FDOOMVBR i486: 125.074
- FDOOMVBR Pentium: 124.383 (−0.6%)
In the case of the Cyrix/IBM 6x86, the difference is minimally better, but I’d need to test more models at different frequencies to draw a solid conclusion (I only have this one). As for the K5, results are slightly worse, but again, more frequencies would be needed to confirm that.
And now for the one that completely surprised me, the IDT WinChip! This new code shouldn’t be faster on that CPU, since it has a design closer to a 486 than a Pentium… but the results speak for themselves:
IDT WinChip C6 200:
- FDOOM13H i486: 84.397
- FDOOM13H Pentium: 106.209 (+25.8%)
- FDOOMVBR i486: 110.371
- FDOOMVBR Pentium: 150.061 (+35.9%)
The conclusion I can draw from this CPU is that SHLD/SHRD instructions are extremely slow on the WinChip, and should be avoided whenever possible.
I still need to test more architectures such as the K6, K7, or Pentium II (or maybe some rarer ones like the Transmeta). If anyone can help me with that, I’d really appreciate it. In theory, it should also be faster on the K6 since it decodes SHLD/SHRD poorly and they’re not very parallelizable. I’m attaching a compiled version that includes the new code. If you want to check and compare your results with mine, please use the included CFG (Ultimate Doom 1.9 is required but not included). The commands I used are:
fdoom13h -timedemo demo3 -i486
fdoom13h -timedemo demo3 -pentium
fdoomvbr -timedemo demo3 -i486
fdoomvbr -timedemo demo3 -pentium
Will you be releasing this update?
Reply 1243 of 1261, by ViTi95
Yes, of course! I'm still working on this update; I just need more time to fix some issues in the newer code and add render paths for MMX enabled CPUs. I've also found that column rendering is a major issue on AMD K6 CPUs due to cache thrashing, so I'm looking for a way to fix this problem.
Reply 1244 of 1261, by mockingbird
ViTi95 wrote on 2025-11-14, 23:52:
How about go one step further and add CMOV?
(Decommissioned:)
Reply 1245 of 1261, by ViTi95
For now I’m focusing on MMX. The render functions (columns and spans) will benefit from this more than from CMOV instructions.
Reply 1246 of 1261, by mockingbird
ViTi95 wrote on 2025-11-17, 07:19:
My dream is to get FDM768VBR (1024x768) smoothly playable on a P4 1.6Ghz.
(Decommissioned:)
Reply 1247 of 1261, by ViTi95
There is still a long way to go before high resolution modes work in an optimized way. For now, there is one major issue: column rendering is not optimal in backbuffered modes due to cache thrashing (very well explained by the Rum and Raisin Doom creator: https://github.com/GooberMan/rum-and-raisin-d … osed-Backbuffer. If you approach a wall and the performance drops to very low FPS, then you're encountering this issue. VBE2 Direct modes do not suffer from this problem, but they only write 8-bit data at a time, which is not optimal for PCI or AGP cards. Using MMX or SSE2 does not fix this issue, it only allows processing more than one pixel at a time, but the underlying cache problem remains the same.
Reply 1248 of 1261, by theelf
ViTi95 wrote on 2025-11-18, 08:34:
Hi, greetings! any chance of 320x400 mode? is the only high resolution for me look good, for now i use 640x400 and F5, but will be nice a non vesa option
gracias! thanks a lot
Reply 1249 of 1261, by ViTi95
Yes, it's doable, but for now the next release is focused on optimizations for fifth gen x86 CPUs. I've learned how to write MMX code, and the MMX column renderer is fully working (2 pixels per loop). The speedup isn't huge, but at least it's not slower. Tests on my Pentium 200 MMX (VBE2 backbuffered 640x400 demo3):
- Unrolled non MMX column renderer: 49.872 fps
- Rolled 2 pixels per loop MMX column renderer: 51.487 fps (+3.2%)
I expect a bigger speedup from the MMX span renderer.
Reply 1250 of 1261, by ViTi95
Some dev updates: I've implemented MMX span rendering (2 pixels per loop), with some nice FPS improvements on the Intel Pentium MMX and Rise mP6 CPUs. And definitely there are two CPUs that do not benefit from using MMX at all: the Cyrix 6x86MX (and possibly the Cyrix MediaGXm, although I haven't tested it) and the IDT WinChip. Updated benchmarks:
Intel Pentium MMX 200
- 486 code path: 49.237 fps
- MMX code path (memcpy + columns + spans): 57.120 fps (+16%)
Rise mP6 200 (66MHz bus)
- 486 code path: 37.432 fps
- MMX code path (memcpy + columns + spans): 49.634 fps (+32%)
EDIT: I'm looking for someone who has an IDT WinChip2 and wants to test this new MMX rendering code. My guess is that it should be faster on the WinChip 2 due to its dual issue MMX upgrade.
Reply 1251 of 1261, by marxveix
Transmeta Cursoe cpus have MMX, starting from 333MHz, even if the MHz numbers are high, they are slow CPU-s.
533Mhz had problems with Duke Nukem 3D framerate, choppy experience at 640x, integrated sound was enabled.
I had better experience with this duke3d dos port: Duke07 - another MS-DOS port of Duke3D
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 1252 of 1261, by ViTi95
FastDoom 1.2.0 is now available!
https://github.com/viti95/FastDoom/releases/tag/1.2.0
Changelog:
- Fixed span rendering in backbuffered modes (potato detail and resolutions above 320×200)
- Minor optimizations to span rendering in backbuffered and VBE2 direct modes
- Added new span rendering routines for CPUs with slow SHLD performance (high detail)
- Added new column and span rendering routines optimized for CPUs that benefit from small code that fits in the L1 cache (high detail)
- Added new column and span rendering routines optimized for CPUs with MMX support (high detail)
- Optimized code paths for Intel Pentium, Pentium MMX, Pentium II, AMD K5, AMD K6, IDT WinChip, Rise MP6, Cyrix 6x86, and Cyrix 6x86MX CPUs in backbuffered and VBE2 direct modes
- Removed 386SX optimizations for backbuffered and VBE2 direct modes, as these modes are too demanding and the performance gains were negligible
- Minor BSP rendering optimizations, especially for AMD K6 and other CPUs that perform poorly with ROL/ROR instructions
- Switched NASM output from OBJ to COFF format, enabling larger ASM files to be built (some development builds failed at 1600×1200 resolutions)
- Optimized backbuffer-to-VRAM copy functions using MMX instructions
- Optimized backbuffer-to-VRAM copy functions using FPU instructions
- Added automatic CPU capability detection (FPU, MMX, etc.)
Reply 1253 of 1261, by appiah4
Late to this, but I will be trying it out on my U5-40 later this week, thank you Viti95.
Reply 1254 of 1261, by 7F20
appiah4 wrote on 2026-02-03, 08:36:
Maybe I missed something, but how can you run it on a newer RISC-V processor?
Reply 1255 of 1261, by maxtherabbit
7F20 wrote on 2026-02-03, 22:16:
He's talking about the UMC "Green CPU" U5S @40MHz
Reply 1256 of 1261, by 7F20
maxtherabbit wrote on 2026-02-03, 22:48:
Whoops! I do know of the UMC stuff vaguely, but never seen them referred to that way before.
Reply 1257 of 1261, by rasz_pl
sqpat realdoom developer has some interesting micro optimization ideas https://www.doomworld.com/forum/post/3004917 and figured out a way to do profiling using martypc emu
"Over the weekend another cool thing i figured out how to do was get martypc to spit out CS:IP for every cycle and run it through a few scripts to get counts for CS:IP over 7-8 frames. I would like to do this for an entire timedemo, then process the file and compare with the linker map. If I do this, in theory I should be able to get a runtime percentage for every function in the game, and identify hotspots. Some quick things stood out - the "dc_iscale = 0xffffffffu / spryscale" line and doing that 32x32 division in rendersegrange is responsible for the most individual frames, even with all the 'quick outs'. The final lines of drawcolumn and drawspan of course also come up a lot. Then the multiplications in P_DivlineSide are actually super heavy and seem to represent most of the physics code time."
of course martypc is 8088 only, but same thing could be modded into 86box for example.
Reply 1258 of 1261, by y2k se
I think I've found a bug with 1.20. When advancing maps, the map id text on the automap doesn't update to the new map. I'm using the 13H executable.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 1259 of 1261, by ViTi95
I'll take a look, I'm sure I introduced a bug when I made changes to how the executable's texts are stored 😅
