First post, by lijiaxuan
Hi, I've got an SC-55 and I'd like to hook it up to my Pentium 4 Windows ME retro PC today. However, in the MIDI menu, I can only find Microsoft wavetable and the card's built in MIDI synthesizer. There isn't an option for the game port at all.
I am currently using the Dell WDM driver for Sound Blaster PCI 64, which is the card I have. I am really sure how I would be able to enable the game port.
Thanks a lot.
Reply 1 of 5, by lijiaxuan
Here are the photos
Reply 2 of 5, by NeoG_
The Dell OEM AudioPCI 64V CT5807 does not have a joystick/midi port, so if you install that driver obviously it will not be present in hardware devices
https://theretroweb.com/expansioncards/s/crea … dell-oem-ct5807
If you have the Dell OEM AudioPCI 64 CT5803 with joystick port you will need to install the driver for that card
https://theretroweb.com/expansioncards/s/crea … -pci-64-dell-ga
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 3 of 5, by lijiaxuan
Thanks a lot. Turns out I am using the wrong driver 'cuz I do have the CT5803. Oh also, I am wondering which driver I could use with CT4730, another Ensoniq-style card.
Reply 4 of 5, by NeoG_
The CT4730 is a non-OEM Sound Blaster PCI 64V, drivers are at the bottom of this page
https://dosdays.co.uk/topics/audiopci.php
Or on Internet Archive
https://archive.org/details/pci-64-v
Reply 5 of 5, by lijiaxuan
NeoG_ wrote on 2026-04-21, 22:41:
The CT4730 is a non-OEM Sound Blaster PCI 64V, drivers are at the bottom of this page […]
Thanks a lot
