My K6-II machine
First post, by keropi
I have built this machine for my DOS + win9x gaming needs (most recent game I will ever run on it will be UNREAL 1 , and I found K6-II cpu's to be very tolerant in old dos games too!)
motherboard: Gigabyte GA-5AX rev4.1 , ATX, AlladinV based, AGP slot, 2xISA and no HD limits that I have found 😁
CPU: AMD K6-II AFX 450mhz
RAM: 2x128MB SDRAM 133mhz
a trusty Voodoo3/3000 AGP
the mandatory Roland LAPC-I
a nice SB16 2230 (might exchange it with a 1740 though)
coupled with a DB60XG daugterboard
for now it serves me well in both DOS and win9x games that I have 😁
I have found the mobo very stable, and after adjusting some BIOS settings (WIP) agp perfomance is very good too!
Any suggestions are HIGHLY welcomed! 😉
Reply 1 of 34, by keropi
I also have 500mhz and 550mhz K6-II cpu's as spares, should I upgrade ? In DOS I have no probs now with the agp lfb settings, but a higher cpu will help win games... what do u think?
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 34, by Amigaz
Nice pieces of hardware!
You have a picture of the system in action?
There's no reason why you shouldn't use a faster CPU, it will only benifit Windows games and heavy SVGA games....for older DOS games even a Pentium 1 is too fast so no reason to worry about speed problems since you can't avoid them 😁
Reply 3 of 34, by keropi
currently the system is inside a NOS Asus retro-beige tower, but it is a mess from testing... will post some good pics ASAP...
maybe after I replace the cpu?
I just want to have this ONE and ONLY dos/win9x old-games-machine , I also have a 486/100 in a classic pizza-box case, but I would only like one machine...
Reply 4 of 34, by Amigaz
That's my dream too but sadly it can't be a reality 😢
Too many games from the late 80's and early 90's doesn't even run nice with a 486
Just look at Zool 1 & 2 for example...they won't even start on a 486 or faster
Reply 5 of 34, by keropi
I forgot to mention that I still have my 386sx PS1/pro machine 😀
now upgraded to 486slc2/40mhz , gg486 style
Reply 6 of 34, by WolverineDK
Amigaz wrote:
That's my dream too but sadly it can't be a reality :depressed: […]
eerhm could you refine, what you mean by a 486 ? since my first (my familys first) pc was a 486 Olivetti 25 MHz with 4 megabytes of ram, and there I ran zool 1 or 2 fine. But then again, it is no wonder why it ran fine. It was an extremely slow computer in the first place.
Reply 7 of 34, by Amigaz
Slowest 486 machine I tried it on so far is on my 486DX 50 EISA system
Since your 486 was a 25mhz it must have been a 486SX?
Reply 8 of 34, by WolverineDK
Yeah it probably was, it was there I learned my real footsteps, when it came to learning about Dos, and its batch files. The only "real programming" I can figure out.
Reply 9 of 34, by fillosaurus
Well, about games not running well on faster machines. I found out on my own that Alone in the Dark 1 and 2 do not like cpu's faster than 486/33 or 40. Tried them with a DX2/66 and they did not work. Put in a DX/33 and they did. Weird...
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 10 of 34, by Amigaz
Did they not start?
They run fin on my 5x86 133mhz machine here
edit: can't get them to recognise any FM sound device though...can just get digital sound 😜
Reply 12 of 34, by keropi
and here are my speed results, I think they are very good 😁
Reply 13 of 34, by Amigaz
keropi wrote:
and here are my speed results, I think they are very good :D […]
damn....now you realize how sloooow a socket 3 machine really is 😳
a 3-4 year leap really made a difference in speed and reliability
Reply 14 of 34, by leileilol
My own k6-2 433 is slower than a p2 233 🙁
Reply 16 of 34, by leileilol
it's a compaq laptop actually, it scores in Quake as good as a Pentium Pro 200 does 🙁 it also has unavoidable CPU 'hiccups' no matter what OS is used.
Reply 18 of 34, by keropi
here are some WIP pics ... I will change the HD cable with a rounded one I think... cables are a mess right now...
also there is a slight change... I now use a CT1740 SB16 (thanks amigaz!) and a DB50XG daughterboard 😁
also installed are a PCI network adapter and a USB2 card (for easy exchange of files from win98SE)
NOTE: here is a generic USB MASS STORAGE driver for win98, it works PERFECT and is very handy! http://www.technical-assistance.co.uk/kb/usbmsd98.php
Reply 19 of 34, by prophase_j
There is something almost.. sexy about a full size ISA card.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
