Sorry - not familier with that exact board.
I can run DOS on most of my "modern" systems (to be fair I don't have anything super-modern). My question is: How did you get DOS onto your CF?
I find that with things like ACPI, UEFI, massive hard drive support etc. it can be tricky to get a bootable DOS partition working.
The fact that you get to "Loading MS-DOS" means it's running in real mode and started a boot sector/sequence. Most likely it's a problem with the hard drive partition/formatting.
Most of my systems have a floppy (or GeTek) and I can boot DOS, then go through the usual FDISK - FORMAT/S if I want to actually install DOS, some that don't have floppies have BIOS that recognizes a USB floppy drive which also works. Some can boot a USB stick with DOS on it as well.
If you can a floppy (or image) to boot, you at least know DOS can run in the system. Then it becomes a matter of figuring out how to prepare drive and partition to be properly accessable from DOS.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
