Tomy Tutor emulation
First post, by yevrowl
Looking for an emulator that lets me paste text from the clipboard or import it in some other convenient way.
Reply 1 of 4, by wierd_w
You should consider asking in the TI99/4A section at AtariAge. It has has... very active.. greybeards and programmers in it.
It has a dedicated subforum for Tomy Tutor.
https://forums.atariage.com/forum/345-tomy-tu … ortex-990-mini/
More than likely, you can use Classic99 with the process to create a memory dump cartridge image, then modify it after the fact to create a Tomy capable one.
There is a thread detailing this process in the normal TI99/4A section. It has been used to make cartridge images of many classic BASIC titles for use with a FinalGrom.
The Tomy has a different memory space, but mostly identical hardware to a 99/4A. Manual editing with a hex editor may get you a Tomy capable cartridge.
This is a pinned thread in the programming subforum. It contains a veritable treasure trove of useful things for 4A development.
https://forums.atariage.com/topic/153704-ti-9 … ment-resources/
Reply 2 of 4, by Robbbert
Can't MAME do that? (not near suitable computer right now)
Reply 3 of 4, by wierd_w
MAME has tutor emulation, but I dont know about "paste" support.
Reply 4 of 4, by yevrowl
Robbbert wrote on 2026-04-23, 01:30:
wierd_w wrote on 2026-04-23, 02:21:
MAMEUI has a built-in clipboard paste feature. However, in the case of Tomy Tutor, it works extremely poorly — characters disappear in almost every line.
