First post, by cloverskull
Hey friends, I got the itch to build a Windows 98 machine. I'd like to have a 1.4GHz Tualatin processor and an NVidia card running in AGP. I'd also like two Voodoo 2s in SLI on the PCI slots and a good ISA sound card option.
Can someone please advise the following? 😀
1. Motherboard
2. NVidia card
3. Sound card
4. RAM
5. Anything I've missed?
Thanks!
Reply 1 of 11, by tomcattech
1. Motherboard - Socket 478 with an Intel chipset Never mind, missed that you were going with Tualatin
2. NVidia card - (Going with Voodoo2 ?) GeForce 4 Ti
3. Sound card - Soundblaster Live or Audigy 2 ZS - (Go PCI)
4. RAM - 512 MB
Note that unless you have two voodoo 2s laying around, expect to pay way too much for them....
I either fix it or break it permanently... there is no try.
Reply 2 of 11, by zwrr
Are you set on using a Tualatin processor while simultaneously requiring an ISA sound card? In that case, you can opt for a motherboard featuring the VIA 694T chipset. If you are unable to find one, a 694X chipset motherboard is also a viable option, though it may require you to make some minor physical modifications to both the CPU socket and the processor itself.
My recommendations are as follows:
Processor: Tualatin Pentium III-S
Motherboard: Based on the VIA 694T chipset (or 694X—modification required)
Memory: 512MB
Graphics Card: GeForce 4 Ti series (if Direct3D 9 support is required, the FX series is also an option)
Sound Card: Creative AWE64 Gold
I don't quite understand the rationale behind using an ISA sound card—is it for DOS compatibility? If you do not specifically require that capability, using an 815EPT motherboard paired with a PCI sound card would be a far better choice.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 3 of 11, by Shponglefan
Before making any recommendations it would be good to know the specific goal(s) for the build.
Are there any performance goals for such a system? What specific games are you wanting to use it with?
For example, if the intent is to just use Win98 and Windows games, then an ISA sound card isn't really needed. There are PCI sound cards that would be preferable.
If the goal is to cover both DOS era and Win 9x era, especially if running native DOS, then there is more of a reason to have an ISA sound card (or two).
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 11, by RetroPCCupboard
I would say Geforce 2 Ti and Aureal Vortex 2 would be a good match.
Reply 5 of 11, by cloverskull
Thanks for all the recommendations! Yes, I do intend to do quite a bit of DOS gaming and would like this computer to handle DOS games with full sound support as well as Windows 98 games.
Reply 6 of 11, by RandomStranger
Do you have a budget?
You want a Voodoo 2 SLI and if you already not have those you already looking to spend 250-300€ at minimum for those alone. Then you might as well go and get an Aureal Vortex 2 too.
Reply 7 of 11, by cloverskull
In case anyone cares, here's my build details:
Diamond DFI CA64-TC motherboard 694T
Pentium-III 1.4GHz
512mb RAM
NVidia GeForce 4 Ti 4200
2 Voodoo 2 cards in SLI for Glide
Matrox MAT-M3D for SGL
ESS MK1869 XTREME
Hopefully I don't hit any snags with this build, it's my first Windows 98/DOS machine in a long time and I'm looking forward to it. My main goals are to play old Sierra and LucasArts games as well as some 3D titles (Quake 2, Unreal, Tomb Raider, etc).
Reply 8 of 11, by H3nrik V!
cloverskull wrote on Yesterday, 00:10:
In case anyone cares, here's my build details: […]
Pentium-III 1.4GHz
512mb RAM
ESS MK1869 XTREME
I was told, that somebody found out that a PowerVR card (the Matrox M3D) is pretty much disabled by nVidia drivers, so you might not be able to use it with the GeForce card.
Reply 9 of 11, by MagefromAntares
It is a quite nice configuration that you have chosen, one thing to note is that 694T is a VIA Chipset, and VIA Chipsets of that time generally require well selected driver version to run well, so you might have to try multiple driver versions to get optimal performance and stability.
The GeForce 4 Ti 4200 is a real powerhouse when combined with a P3 and a quite good companion card for even a Northwood P4, so that is a good choice.
I have no experience with running Voodoo 2 in SLI, so I cannot comment on that.
Reply 11 of 11, by H3nrik V!
Re: PowerVR Fun Thread
A little read here regarding GeForce drivers and PowerVR (Matrox M3D)
