After installing OCCT 4.4.1, I found out that Command Rate 1T is not 100% stable at 2.2Ghz. OCCT reports error after about 1 hour. Memtest86, prime95, SuperPI 32M worked fine with CR1 even for very long 8+ hour periods. I do have a couple of 1GB DDR400 modules so I will swap them around, but high quality modules like Corsair or OCZ are very rare. nd22 never ran OCCT, so it is possible his 2x 1GB RAM sticks weren't 100% stable at CR1 either. I used 2x Kingston 1GB DDR400 with heatspreader.
This indicates there is some kind of race condition in the CPU that worsens as CPU frequency increases when 2 DDR400 memory sticks are used:
- At 2.4Ghz and CR1, memtest86, prime95 pass but SuperPI 32M fails within a few minutes
- At 2.4Ghz and CR2, memtest86, prime95, SuperPI 32M and OCCT pass
- At 2.2Ghz and CR1, memtest86, prime95 and SuperPI 32M pass, but OCCT fails after 1 hour.
This behaviour was observed in both Turion 64 ML-34 and ML-37 so it isn't just a matter of unlucky silicon.
It is unlikely that one could run at DDR500 or higher with 2x 1GB memory modules in s754. This limits safe usage of CR1 to very expensive memory modules or 1x 1GB DDR400 (win98+winXP dual boot, nForce3/VIA).
When we run at 2.4Ghz, CPU voltage is 1.44V. At 2.2Ghz, CPU voltage is 1.41V. It's nice that it's adjusted up for us.
Gigabyte GA-K8NE is unable to set higher/lower voltage in BIOS.
Asus K8N-E can set lower voltage, but not higher voltage. Higher voltage is ignored and default voltage is used.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
